This question may sound very simple but the code I wrote for a seven segment display adder with pushbuttons in VHDL takes so long to generate a bitstream. I reset and tried again several times but it has been about 4 hours now and the bitstream is not generated. I don't think the code will be necessary for this question but if it matters in the answer of the question, I would love to include it. I am using Vivado 2017.2 wrote two source and a constraints file for the FPGA Basys3 and the language that I am using is VHDL.
Thanks in advance for any suggestion.
Main code:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use ieee.std_logic_unsigned.all;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if instantiating
-- any Xilinx leaf cells in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity main is
port(b1,b2,b3,b4 : in STD_LOGIC;
clk : in STD_LOGIC;
sseg : out STD_LOGIC_VECTOR(0 to 6);
anodes : out STD_LOGIC_VECTOR(3 downto 0);
reset : in STD_LOGIC
end main;
architecture Behavioral of main is
signal bcd1, bcd2, bcd3, bcd4 : STD_LOGIC_VECTOR (3 downto 0);
signal clk2 : STD_LOGIC;
signal pushbuttons : STD_LOGIC_VECTOR(3 downto 0);
signal db_pushbuttons : STD_LOGIC_VECTOR(3 downto 0);
signal counter : STD_LOGIC_VECTOR(1 downto 0);
signal clk_divider : STD_LOGIC_VECTOR(20 downto 0);
component Debounce is
port( cclk : in STD_LOGIC;
inp : in STD_LOGIC_VECTOR(3 downto 0);
cclr : in STD_LOGIC;
db : out STD_LOGIC_VECTOR(3 downto 0)
end component;
begin
pushbuttons <= b4 & b3 & b2 & b1;
Db : Debounce port map
( cclk => clk2,
inp => pushbuttons,
cclr => reset,
db => db_pushbuttons);
process (clk)
begin
if rising_edge(clk) then
if clk_divider <= "1100001101010000" then
clk_divider <= clk_divider + 1;
clk2 <= '0';
else
clk_divider <= (others => '0');
clk2 <= '1';
end if;
end if;
end process;
process (clk2, reset)
begin
if reset = '1' then
-- do something here
bcd1 <= "0000";
bcd2 <= "0000";
bcd3 <= "0000";
bcd4 <= "0000";
elsif rising_edge(clk2) then
counter <= counter + 1;
if db_pushbuttons(0) = '1' then -- db_b1
if bcd1 <= "1000" then
bcd1 <= bcd1 + 1;
else
bcd1 <= "0000";
end if;
elsif db_pushbuttons(1) = '1' then -- db_b2
if bcd2 <= "1000" then
bcd2 <= bcd2 + 1;
else
bcd2 <= "0000";
end if;
elsif db_pushbuttons(2) = '1' then -- db_b3
if bcd3 <= "1000" then
bcd3 <= bcd3 + 1;
else
bcd3 <= "0000";
end if;
elsif db_pushbuttons(3) = '1' then --db_b4
if bcd4 <= "1000" then
bcd4 <= bcd4 + 1;
else
bcd4 <= "0000";
end if;
end if;
end if;
end process;
process (counter, bcd1, bcd2, bcd3, bcd4)
variable display : STD_LOGIC_VECTOR(3 downto 0);
begin
case counter is
when "00" => anodes <= "1110"; display := bcd1;
when "01" => anodes <= "1101"; display := bcd2;
when "10" => anodes <= "1011"; display := bcd3;
when "11" => anodes <= "0111"; display := bcd4;
when others => null;
end case;
case display is
when "0000" => sseg <= "0000001"; --0
when "0001" => sseg <= "1001111"; --1
when "0010" => sseg <= "0010010"; --2
when "0011" => sseg <= "0000110"; --3
when "0100" => sseg <= "1001100"; --4
when "0101" => sseg <= "0100100"; --5
when "0110" => sseg <= "0100000"; --6
when "0111" => sseg <= "0001111"; --7
when "1000" => sseg <= "0000000"; --8
when "1001" => sseg <= "0000100"; --9
when others => sseg <= "0010000"; --e, represents error
end case;
end process;
end Behavioral;
Debounce code:
library IEEE;
entity Debounce is
port(cclk : in STD_LOGIC;
end Debounce;
architecture Behavioral of Debounce is
signal delay1, delay2, delay3 : STD_LOGIC_VECTOR(3 downto 0);
begin
process (cclk, cclr)
begin
if cclr = '1' then
delay1 <= "0000";
delay2 <= "0000";
delay3 <= "0000";
elsif rising_edge(cclk) then
delay1 <= inp;
delay2 <= delay1;
delay3 <= delay2;
end if;
end process;
db <= delay1 and delay2 and delay3;
end Behavioral;
Constraints:
## Switches
set_property PACKAGE_PIN V17 [get_ports {reset}]
set_property IOSTANDARD LVCMOS33 [get_ports {reset}]
set_property PACKAGE_PIN V16 [get_ports {cclr}]
set_property IOSTANDARD LVCMOS33 [get_ports {cclr}]
##7 segment display
set_property PACKAGE_PIN W7 [get_ports {sseg[0]}]
set_property IOSTANDARD LVCMOS33 [get_ports {sseg[0]}]
set_property PACKAGE_PIN W6 [get_ports {sseg[1]}]
set_property IOSTANDARD LVCMOS33 [get_ports {sseg[1]}]
set_property PACKAGE_PIN U8 [get_ports {sseg[2]}]
set_property IOSTANDARD LVCMOS33 [get_ports {sseg[2]}]
set_property PACKAGE_PIN V8 [get_ports {sseg[3]}]
set_property IOSTANDARD LVCMOS33 [get_ports {sseg[3]}]
set_property PACKAGE_PIN U5 [get_ports {sseg[4]}]
set_property IOSTANDARD LVCMOS33 [get_ports {sseg[4]}]
set_property PACKAGE_PIN V5 [get_ports {sseg[5]}]
set_property IOSTANDARD LVCMOS33 [get_ports {sseg[5]}]
set_property PACKAGE_PIN U7 [get_ports {sseg[6]}]
set_property IOSTANDARD LVCMOS33 [get_ports {sseg[6]}]
#set_property PACKAGE_PIN V7 [get_ports dp]
# set_property IOSTANDARD LVCMOS33 [get_ports dp]
set_property PACKAGE_PIN U2 [get_ports {anodes[0]}]
set_property IOSTANDARD LVCMOS33 [get_ports {anodes[0]}]
set_property PACKAGE_PIN U4 [get_ports {anodes[1]}]
set_property IOSTANDARD LVCMOS33 [get_ports {anodes[1]}]
set_property PACKAGE_PIN V4 [get_ports {anodes[2]}]
set_property IOSTANDARD LVCMOS33 [get_ports {anodes[2]}]
set_property PACKAGE_PIN W4 [get_ports {anodes[3]}]
set_property IOSTANDARD LVCMOS33 [get_ports {anodes[3]}]
###Buttons
##set_property PACKAGE_PIN U18 [get_ports btnC]
# #set_property IOSTANDARD LVCMOS33 [get_ports btnC]
set_property PACKAGE_PIN T18 [get_ports b1]
set_property IOSTANDARD LVCMOS33 [get_ports b1]
set_property PACKAGE_PIN W19 [get_ports b2]
set_property IOSTANDARD LVCMOS33 [get_ports b2]
set_property PACKAGE_PIN T17 [get_ports b3]
set_property IOSTANDARD LVCMOS33 [get_ports b3]
set_property PACKAGE_PIN U17 [get_ports b4]
set_property IOSTANDARD LVCMOS33 [get_ports b4]
