PLC Standards Compliance Ensures Future-Proof Solutions
( two slightly different stds )
IO-Link Versions 1.0 and 1.1.2
IEC IEC61131.9 SDCI
Selectable means USA or EU stds for C/Q IO interfaces. (clk & data high voltage long wire bus standards)
Optional 6mA/7mA Current Loads at Both 24V Inputs is the selection
For use with hi-side logic in 500m communication buswire pairs up to 400Kbaud ??
ie. 4k load to ground from 24V/4k = 6mA
e.g. IEC 61131 Type 1 uses 7mA with noise margins that @Arsenal pointed out for Type 2
Ref: IO-Link is the first standardised IO technology worldwide (IEC 61131-9) for the communication with sensors and also actuators. http://io-link.com/share/Downloads/At-a-glance/IO-Link_System_Description_engl_2013.pdf
A logic "1" is defined by the received voltage from a defined current in a selected load resistor to ground. If IO link is 6mA * 4k =24V then IEC611131.9 is 7mA * ?? .... and the thresholds are used for noise margins.
If you search hard enough you can read all the IEC standards free.
http://www.plcopen.org/pages/tc1_standards/ what each dash number means
