There are plenty of ways to connect to a wire and measure what is going through it that involve breaking the insulation around the wire (such as positap connectors).
It is my understanding that a wire with current flowing through it creates a magnetic field around the wire. Could this effect be used to measure the amount of current flowing through a wire without breaking them? If so, can it be done with a small enough component to make it comparable to positap connectors?
888
  • 179
  • Yes, it can be done. It's not as accurate. – user253751 Nov 23 '17 at 23:17
  • Yes, you can measure the amount of current using a clamp meter, usually the currents need to be relatively high, its mostly used in industrial applications where you need to measure high currents without breaking the cable. – S.s. Nov 23 '17 at 23:19
  • Hall-effect sensors are pretty common, there are probes for oscilloscopes and for DMMs. The clamp is less than 10mm long in many cases. – Ale..chenski Nov 23 '17 at 23:19
  • i.e. How does a current clamp work? https://electronics.stackexchange.com/questions/341156/how-does-a-dc-clamp-meter-measure-current/341166#341166 – Tony Stewart EE75 Nov 23 '17 at 23:24
Current clamps are a mature product category. They are best suited to measuring AC or transient signals.
J_H
  • 121
  • And there are instrumentation DC current clamps that measure down to microamps DC. Generally used for non invasive testing on current loops. – R Drast Nov 27 '17 at 08:56
