Two fuses, for two reasons.
First, I want to establish some arbitrary values. For the purposes of the below, I will assume the devices will draw 1 amp while idle, be connected to either one 10 amp fuse, or two 5 amp fuses, and become damaged at 7 amps.
Depending on how sensitive these devices are, limiting the current draw of the two devices may not be sufficient to prevent one from becoming damaged. Imagine that one or both devices are idle when one device suddenly malfunctions. A short circuit causes it to draw 8 amps of current, well beyond the 7 amp damage-point. With a single fuse, the total amp draw is 8 + 1 = 9 amps, so the fuse doesn't blow and the device is damaged. With two fuses, the five amp fuse on the malfunctioning device blows, preventing further damage. This isn't a contrived scenario, most devices are in standby most of the time, and, although some malfunctions can cause sudden power spikes, others can cause slow burns. I could answer the question more fully if I actually knew what the devices were.
Another reason is that, depending on the nature of the devices (From your question, maybe high power electronics?), I could imagine that one may internally malfunction and destroy the other. I really couldn't say whether this was a possibility without more information, but I would consider it. With a fuse on each device, each device has its own protection and you don't have to worry about hooking up another device to the circuit, removing one device from the circuit, or changing the nature of one device. You can rest assured that each is separately protected from a surge. It's just good practice.
If this device is a low-cost device, a low power device, or a temporary situation, it wouldn't be worth the bother. I would say that if it was worth the effort of asking the question, its worth a couple of bucks for a separate fuse.
