My eBike came with 48 V, 13 Ah battery. I have a 48 V, 20 Ah battery. Can somebody tell me if I can add the second battery to the bike.
I really can't understand that how the difference in Ah will affect my eBike? Please tell me if I can use it.
Transistor
  • 168,990
  • 186
  • 385
    Larger Ah will give you more run-time, as long as the new battery can discharge at the same rate (or more) than your old battery, you should be fine. – Ron Beyer Nov 20 '17 at 03:01
    Ah is a measurement of battery capacity. The thing to look for is if the new battery can supply the current required by your bike. This is measured in A (Amps). You should really check this, but my best guess is that it is okay. The 20Ah battery will just last longer. – Pablo Maurin Nov 20 '17 at 03:02
    That the charger will take longer to give a full charge is obvious, but if the charger is safety smart, and thinks it's still a 13Ah battery, it may quit before full charge because 'the battery is taking too long to charge, something's wrong, safety shutdown'. – Neil_UK Nov 20 '17 at 05:21
The analogy is: Can I drink water from a large bottle or a small bottle?
The answer is: The large bottle contains more water so it will last longer than a smaller bottle.
MatsK
  • 738
