Karnaugh maps show race conditions as adjacent minterms that are not covered in the same implicand. Take the following example:
karnaugh map
We have race conditions when moving from the blue implicand to the green one, and the blue implicand to the red one (wrapping around the top).
My question is this: would this still apply if the adjacent '1' is a don't care, i.e. an 'X'? In this case, let's change the 1 in minterm AB'CD' (bottom right) to an 'X'. Would this still pose a potential race condition with minterm ABCD'?
jeanluc
  • 137
Yes it would.
If you experience the transition A'B'CD' → AB'CD' → ABCD', the output should show 0 → X → 1, which is either 0 → 0 → 1 or 0 → 1 → 1. In both cases, you should see a single 0 → 1 transition in the output.
But with your example, you might see 0 → 1 → 0 → 1 in the output: you have a race condition.
user2233709
  • 1,705
An X (don't care) in the K-map means you can choose to treat that X as either a one or a zero.
In the example given, it's more convenient to treat AB'CD' as a one, otherwise you'd have to split the AB' term into AB'C' + AB'D.
So, yes, you'd have the race condition, but... Do you care if there's an output glitch when transitioning to or from a state in which you don't care what the output is? Probably in most cases, it doesn't matter.
user28910
  • 3,849
