Is connecting a higher-amp (e.g. 2 A) adapter to a lower-amp (e.g. 1.3 A) electrical device safe?
I wonder if it will cause the adapter to over heat and cause fire or cause damage to the electrical device.
stevenvh
  • 145,145
  • 455
  • 667
Jack Safety
  • 41
  • possible duplicate of [Does using a electrical device that is connecting to a series of power extension safe?](http://electronics.stackexchange.com/questions/34035/does-using-a-electrical-device-that-is-connecting-to-a-series-of-power-extension) – Olin Lathrop Jun 17 '12 at 12:57
  • I already voted to close, but I think this is a better question to be a duplicate of: http://electronics.stackexchange.com/questions/16422/limiting-current-from-a-5v-power-supply – Kellenjb Jun 17 '12 at 16:48
  • @Kellenjb, don't know why, but your comment is hilarious :) – abdullah kahraman Jun 17 '12 at 17:34
No it won't overheat the adapter. That's designed to deliver up to 2 A, and everything less than that is safe. If you disconnect the device the current will be zero, and that's also safe. The adapter will supply the required current, not the current it can supply.
Never do the inverse: connecting a 2 A device to a 1.3 A adapter, though.
stevenvh
  • 145,145
  • 455
  • 667
