I have SIM800L module,
when I try AT+CSQ it returns 0,0
when I tried to remove the sim and try again it returns number, 0 (25,0)
and I cannot register to a network
so AT+CREG? returns 0,2
should I activate something or do another command before trying to do CSQ or either connect to a network..
when I try: AT+COPS=?
it lists all networks available, but cannot connect to any of them
thank you
SamGibson
  • 17,231
  • 58
HSLM
  • 163
I found the solution, it was from the power it takes. when the module is trying to connect to a network it consumes a lot of power, so I lower down the resistor.
now it is stable and connect smoothly.
try to check your module datasheet and check the power consumption
HSLM
  • 163
    Congratulation on realizing that power issues were to blame, as they often are for these. However a fixed "resistor" does not belong in the power supply circuitry of this module. If you are using one, you are taking a horribly mistaken approach. Even engineering a suitable *voltage regulator* is enough of a challenge that many projects just run these off the single cell they were designed to use in their original life as limited-feature mobile phones. – Chris Stratton Sep 29 '18 at 21:49
