I have bought a 5 Volts 2 Amps USB Wall Charger off of Aliexpress for about $1.70. Let's call it cheap charger. It looks a lot like this one (stock image): USB Wall Charger
I want to use this USB charger as a power supply for my project. Said project includes 30x WS2812 (incl. 5050 LED) and an ESP8266. This setup will draw something like 1,3 A of current at 5 Volts when the LEDs are on full brightness.
When charging a phone, the charger will heat up slightly. But powering the mentioned components will heat it up even further (from how hot it feels). This leads me to not trust the rating anymore (the 5V 2A is written on the back of it). This is reinforced when using another 5V 2A USB Charger, that came with a tablet. Let's call this one regular charger. This one only slightly heats up.
Question: Is there a way for me to determine what current my charger can safely supply?
Please keep in mind, that I don't have extensive tooling. I only have a digital multimeter and another (bigger) power supply. The USB connector cable that I also bought there ($0.16) doesn't have wires for D+/D-. So measuring the resistance is more or less impractical.
To differentiate against other questions:
After the suggestion by @Jogitech I tested the cheap charger and it maxed out at around 1.5 A. The multimeter shows a voltage of around 4,1 V at this point. The LEDs started flickering so I stopped there.
I also tested the regular charger, that came with a tablet (this one is also rated 5V 2A). Using this one, I was able to draw the full 2 A of current while the multimeter still showed 5 V.
Conclusion: Like @user2497 said in the comments, I will be looking for a new power supply, that can actually power the circuit without the constant fear of breaking.
    What is your definition of "safely"? Obviously not the same one as the manufacturers, since they rated it for 2A and it will very likely be able to supply that just fine without burning into flames spectaculrarly. For that price point I won't trust it to be very durable though – PlasmaHH Nov 03 '17 at 12:39
    Crank up the load until you see a voltage drop. Then use 75-80% of that as your absolute max. I had similar woes. I eventually settled on IKEA 3-port USB supplies, which are exceptionally well-designed. There are teardowns on youtube. Costs about 7-8$. – user2497 Nov 03 '17 at 12:48
  • @PlasmaHH My definition of "safely" includes sleeping next to it (like charging a phone over night). I'm not yet sure if running the device unattended is included. – rollstuhlfahrer Nov 03 '17 at 14:11
  • I found a [detailed review](https://lygte-info.dk/review/USBpower%202A%20Dual%20EU%20USB%20Wall%20AC%20Adapter%20UK.html) of this charger. It is one of the most dangerous chargers ever made… – Gras Double Jan 11 '19 at 06:28
Its hard to say what current a cheap power supply from aliexpress can supply safely. But if the rating says 2A and you only need 1A it should be fine. From your description i assume that the device is not getting too hot to touch for a longer time, which adds to the assumption that 1A load current should be fine. If you want to try a somewhat experiemental approach you can stress the device with say 1.8A (Keep an eye on the output voltage aswell) and monitor its case temperature over a longer duration (until thermal equilibrium is reached). If you are still below or equal 70°C (@20°C ambient temperature) you are totally fine (only valid if the case is non metallic). Have a look at IEC 60950 if you want more detailed Information about how hot the surface of electronic equipment housing is allowed to get.
Jogitech
  • 732
  • They’re actually a bit dangerous, a fire-hazard. – user2497 Nov 03 '17 at 12:49
    @user2497 He did say monitor. One of the aspects of monitor is looking for the magic smoke. – StainlessSteelRat Nov 03 '17 at 13:19
  • Tested it with my current setup for half an hour. The temperature was still low enough to touch it for a longer period of time. I'll try with the 1.8 A load and report back until tomorrow. – rollstuhlfahrer Nov 03 '17 at 14:10
  • So I did what you suggested and tried my luck. At 1.5A (~ 9 W on primary side) the leds started flickering. So that's pretty much the max current I can get. Nothing exploded, so there will be no pictures of broken equipment – rollstuhlfahrer Nov 03 '17 at 19:38
