When I try to draw a line in the Keep-Out Layer in Altium by clicking the tab for the Keep-Out Layer and placing a line, the layer suddenly changes to a different one and prevents me from adding to the Keep-Out Layer. Additionally, when I try to place a line and press the Tab key and try to select the Keep-Out Layer from the Layer dropdown box, it doesn't appear in the list. How can I add shapes to the Keep-Out Layer?
Thanks!
Billy Kalfus
  • 1,021
Altium doesn't allow you to draw standard primitives on the keepout layer. Instead you need to use the Place -> Keepout menu. From within the menu you can select which type of primitive you want to draw on the keepout layer.
DerStrom8
  • 21,042
  • 61
  • 95
One thing that you can do is convert the track/primitive (in my case a drawing imported from .dwg) to keepout, that worked out form me:
Select the objects then go to: Tools>Convert>Convert Selected Primitives to Keepouts
  1. Make sure you're in PCB mode (not board edit mode) by pressing 2 OR View->2D layout mode.
  2. Try changing your layers options in view configurations (on mine by pressing L key) OR by changing the 2D viewing mode.
The place to change the board shape is in the board edit mode
Here are instructions on how to properly draw a keepout layer
One more idea: as a workaround you might be able to make a shape on a different layer and then open up the properties for that shape or line and change it to keepout.
JYelton
  • 32,302
  • 134
  • 249
Voltage Spike
  • 75,799
  • 80
  • 208
The only thing that seems to work is Place/KeepOut/Track. Which is interesting because this places a line not a trace. What used to work was P/L while keepout was selected.
