19
After watching some tear-down videos on YouTube with various lithium battery products (portable chargers, laptop battery, power tools) they all (apart from mobile phones / tablet battery) seem to feature cylindrical battery cells.
Is there a technical reason for this, other than it's a uniform size that tiles relatively well to give manufacturers flexibility in incorporating the cells?
TimB
  • 785
user27511
  • 551
    I do note that a remarkably large number of batteries, lithium or not, use a cylindrical form factor. – Cort Ammon Oct 30 '17 at 18:35
    The battery (not just lithium ion) consists of two materials separated by a thin semi-permeable membrane soaked in electrolyte. One of the simplest ways to make a high capacity battery not a big sheet is to roll it up. Then it's put in a metal tube to protect it from bending. – τεκ Oct 30 '17 at 18:50
    @CortAmmon Chemical cells have been cylindrical for a long time before plates were rolled up. The distance from the centre to the outside is constant. Now even prismatic cells have rolled up plates to gain large surface areas. – KalleMP Oct 30 '17 at 23:13
    They wouldn't fit in battery holders otherwise. – Andrew Morton Oct 31 '17 at 20:31
1) The cylindrical shape is very easy to manufacture - You basically fold the layers around a round object.
2) For the same reason as drinks cans - this shape is something between the Sphere (high strength and damage resistant) and Cuboid (Easy to stack and low space is wasted). It is the best trade-off between strength and volume.
3) This way You can easily stack the batteries - (Parallel and Series connections).
KJA
  • 973
Among other reasons already stated, in 1991 Sony commercialized the first lithium-ion cell and later used it to power their 8mm camcorder. They needed a way to make these new batteries quickly and on a huge scale. At the same time CDs were killing tape sales (remember cassette tapes?). The same equipment that coated magnetic tape with slurry could be used to make batteries in the same way. So basically they had a bunch of equipment and factories that were slowing down and it all kind of lined up. That's why it started that way anyway.
That's a pretty well told story in the industry and if you google you'll probably find a few articles about it. Everyone peddling some new version of the Lion battery or some new battery technology likes to lead with it to show you how old and outdated the batteries you're currently using are.
Some Hardware Guy
  • 15,815
  • 44
I'd say the opposite is the case.
Nearly all alkaline cells (and zinc carbon etc.) are round. The square-ish packs are made up of round cells (e.g. 9V; the larger sizes such as lantern batteries often use C or D cells internally).
The main exceptions are lead-acid and lithium, such as phone batteries. Many small rechargable devices like MP3 players and even my current laptop use these "prismatic" or "pouch" cells as well, which minimise the packaging bulk and weight.
Note that some round Li cell sizes are the same as the common alkalines (14500 is the same as AA but ~3x the voltage which leads to useful tricks to free up space)
Chris H
  • 2,331
  • From the examples that the OP gives, manufacturers could use layers of these flat batteries to fill up a rectangular area, but they tend to just use cylinder shaped cells instead. I read his question as "why round when they could just be stacking these pouch or flat batteries?"... – JPhi1618 Oct 31 '17 at 15:54
  • @JPhi1618, they could. I can speculate as to reason but didn't want to put it in the answer: 18650s are (almost) commodity items - one supplier lets you down and you use another (there's a limit to how much a responsible manufacturer can mix and match) but pouch cells are less standard (dual sourcing them was implicated in Samsung's problems with exploding Notes). Cylindrical cells also seem to have higher (dis)charge currents, useful in some of the OP's applications such as my drill (18650s). – Chris H Oct 31 '17 at 17:28
  • When it comes to power packs, I have examples of both. – Chris H Oct 31 '17 at 17:28
  • In power tools I would also want something tough given that they get handled roughly - pouch cells would want to be in a strong outer case which defeats the object of using them. See also Tesla's use of 18650s (IIRC) – Chris H Oct 31 '17 at 17:31
  • I would imagine that packing cylinders into square shaped packages also helps prevent excessive heat build up since there are air gaps between them where flat batteries would occupy all the space and not allow for convection to pull some heat away. (IANEE) – FreeMan Oct 31 '17 at 18:52
  • @FreeMan that's possible at high currents but the material used to hold them together often blocks airflow – Chris H Oct 31 '17 at 19:19
  • @ChrisH Samsung did initially put the exploding phone problem down to a problem with Supplier A and do an exchange program; only to discover that phones with Supplier B's batteries were also igniting at which point the product was yanked off the market. – Dan Is Fiddling By Firelight Oct 31 '17 at 21:20
A cylinder (or even better, a sphere, but a spherical battery isn't a very convenient shape to use inside a device) is a much more efficient use of material for resisting internal pressure than a box with flat sides, in case the battery fails or overheats.
With a box shape, the sides can bulge outwards and then break off where they join at the edges. A cylinder doesn't have any "edges" except where the end pieces join the cylindrical wall.
Aside from the stress analysis considerations, the shape with the biggest ratio of enclosed area to circumference is also a circle - so even for an unpressurized container, a cylinder uses the least material to hold a given volume. For the same volums, a square section container has about 27% more surface area than a cylindrical one - and that means 27% less "dead weight" and material cost.
alephzero
  • 1,100
  • Cylindrical cells are usually designed to vent easily rather than resist pressure, as a cell that *nearly* resisted pressure would explode – Chris H Oct 31 '17 at 19:24
The simplest reason there are a lot of round cells is the reason that tek states in his comment. The batteries consist of two electrodes seperated by an electrolyte, one set gives the normal voltage. To increase capacity and current capability, the electrodes and seperator are typically very thin and are wound up into a "jelly roll". The easiest way to do this is simply wind it up into a coil and seal it in a can. Hence the round cells.
Prismatic cells, the rectangular ones used in phones and similar electronics, are made in a similar way, they are simply flatter and oblong. This is why a lot of prismatics will have a curved edge.
Redja
  • 660
