I want to know two things,how big does the phased array needs to be to form proper beam and what is the smallest area the beam can be focused.I learned little bit about lasers and with focal lense,the smallest spot that it can be focused is 1 wavelenght in theory,in practice about double.From loudspeaker theory I know that for driver to exhibit directional radiation it needs to be atleast 1 wavelenght big,significant beaming doesnt happen until the driver is 5 times the wavelenght.
But this isnt optics or acustics,how does this work for microwave phased array transmitters? I want to achieve small spot size,around 1cm and very low divergence,pencil like beam,but I also would like to use relatively lower frequencies like 2.4 GHz which have 12.5 cm wavelenght.If it was like speakers and lasers,smallest spot size would 12.5 cm,and the array would be too large,around 60 cm in diameter.
I know that dielectric materials slow down the speed of electric field,thus shortening the wavelenght without increasing frequency,is it possible to use this property to make small size array that is able to focus to spot size that is below 1 wavelenght in vacuum/air?
