Edit: Added gating signal waveforms. Changed some of the graphs, I accidentally put a test circuit waveforms the first time. Current is not that high but offset is there and current is high for a lower inductance.
I am new to using PLECS and power electronics in general. I am trying to simulate a grid-tied power inverter where I am using a 300V dc power source, inverting it to 60Hz AC, and then connecting to a 60Hz AC grid (120 Vrms).
It successfully gives me the voltage I want. But I am getting a 0.567A dc current offset. This offset and the total current gets very high if I reduce the inductor size. Questions:
- Why is there a DC current offset, even across the transformer?
- How to reduce this offset to zero?
- The power output is awfully high. How to reduce it or control the current?
The circuit information is as follows:
I am switching S4 and S3 with a 60Hz (in sync with grid) pulse train with 0.5 duty cycle. S1 and S2 are switched at 60 kHz with sinusoidal pwm.
Duty cycle = (Vc_peak/Vdc)* sin(2*pi*60*t). S5 and S6 are inactive.
When I measure the grid (final output, right side) voltage and current , I get this. Notice that the current wave is not biased at zero!
This graph includes the measurements at the primary side of the transformer, i.e. inverter output. Vc is the inverter output voltage, showing average for clarity. Vs is the sine output voltage after the inductor. Is is the current through the inductor. Igrid is inverted in this graph to match the signs.
Switching waveforms:
Duty cycle of S1. The graph shown is a graph (sine at 60Hz) of duty cycle, actual switching is at rate 60kHz :
Duty cycle of S2 = (1 -Duty cycle of S1). S2 = not S1.
T = 1/60. 50% duty cycle. S3 = not S4.
