The most common way to define clocks synchronous or asynchronous to each other is the set_clock_groups
command. The create_generated_clock
command is not mandatory to make the clocks synchronous.
If clock A and B are defined as follows, my synthesis and STA tools classify them synchronous, but I don't rely on that and I explicitly define my clock groups.
create_clock -name CLK_A -period 10 -waveform "0 5" [get_ports A]
create_generated_clock -name CLK_B -source CLK_A -divide_by 2 [get_ports B]
The clocks listed after the same -group
switch become synchronous. Please note that CLK_A and CLK_B will also be asynchronous to any other clock (X and Y in this case).
set_clock_groups -asynchronous -group {CLK_A CLK_B}
Let's assume that clock X and Y have the following constraints.
create_clock -name CLK_X -period 20 -waveform "0 10" [get_ports X]
create_clock -name CLK_Y -period 15 -waveform "5 10" [get_ports Y]
If we put them into different groups, they become asynchronous.
set_clock_groups -asynchronous -group CLK_X -group CLK_Y
Now we have 3 clock groups in total. We could also define them with a single command as follows.
set_clock_groups -asynchronous -group {CLK_A CLK_B} -group CLK_X -group CLK_Y
