This seems like a question which has been asked multiple times on forums. I researched the problem but I still was unable to figure out the answer which I can at least intuitively understand. So in this simple circuit why is there no current leakage to earth? Assume that it is a true earth ground connection (a rod in the earth for example).
Update: I am giving researched answers below, but not as the only options. I am not satisfied with any of them, and give my explanation as to why. So I am hoping for either an elaboration or an alternative answer.
The answers I have found:-
  1. Here With only one connection to ground there is no circuit for the current to flow through. It can't flow "to" ground, because there is nowhere for it to flow to. There's no difference between ground and a wire dangling in the breeze. However for current to flow there must be potential difference. And because the ground and the battery return has the same potential - why would current prefer to flow specifically to the return point. Especially taken into account that earth can absorb all electrons generated by the battery (on contrary for example to just piece of wire).
  2. Here The ground isn't a great conductor and while it is in parallel with the service, the amount of current returning through the ground is so small it is effectively zero - Firstly this answer implies that there's some leakage occurs which just depends on earth resistance. Also I do not understand which resistance is taken into account. Where it is measured? I think also the answer relates to the several connection of the circuit to the ground.
So anyone can give real physical explanation of this?
KalleMP
  • 4,039
  • 32
Boris
  • 177
  • 1) If there is a potential difference, it is equalized instantly after the connection. So yeah, there would be an instantaneous current. 2) I think it is not an answer. – Eugene Sh. Oct 12 '17 at 18:36
  • @EugeneSh. The question why would it stop then. The current flow can take either path to the ground or to the return.Both with the same potential. Why the second one is preferred? – Boris Oct 12 '17 at 18:38
    2) is an is more applicable to the AC mains situation where there can be some leakage and/or capacitive coupling to ground causing small (AC!) currents to flow. But your example is DC so 2) simply does not apply. – Bimpelrekkie Oct 12 '17 at 18:38
  • @Bimpelrekkie So what is the correct answer? – Boris Oct 12 '17 at 18:39
  • I say that 2 does not apply so..... – Bimpelrekkie Oct 12 '17 at 18:40
  • Ground and return are *the same point*. – Eugene Sh. Oct 12 '17 at 18:40
  • @EugeneSh. If they are the same why current does not flow to the ground. – Boris Oct 12 '17 at 18:41
    Let's turn that around, why **would** the current flow into the ground? What would happen if it did? How would you make that current flow into ground? Would there be a stream of electrons going from the circuit into the ground? Is that sustainable? – Bimpelrekkie Oct 12 '17 at 18:41
  • @Bimpelrekkie It will just flow there. Partially (half of the current) to the return to keep the battery working and partially (another half) to the ground. – Boris Oct 12 '17 at 18:43
  • The current will flow only between points having a potential difference. In order to *maintain* a potential difference over time you need a closed circuit. If you have a potential difference in open circuit, it will get equalized after short time. That's it. The path to ground is open. the path to battery is closed. – Eugene Sh. Oct 12 '17 at 18:44
  • @EugeneSh. Electron reaching the ground connection does not know which direction the circuit is closed or open. It flows to the lowest potentials. Both paths have the same potential. – Boris Oct 12 '17 at 18:46
  • *It will just flow there. Partially (half of the current) to the return to keep the battery working and partially (another half) to the ground.* That is really not true. Current flows in loops and cannot split halfway to somewhere else without returning. – Bimpelrekkie Oct 12 '17 at 18:47
  • But if the electron chooses ground then the ground gets negatively charged making it **harder** for the electron to go there. So it will not. – Bimpelrekkie Oct 12 '17 at 18:48
  • @Boris Yes. Now consider the electron is "choosing" the wrong path and going to the ground. Now the potential of ground have changed! So the next electron will go the other way, until the potentials are equal again. – Eugene Sh. Oct 12 '17 at 18:49
  • @Bimpelrekkie The whole idea of the ground is that it cannot become charged. – Boris Oct 12 '17 at 18:49
  • @Boris It's relative. So it's the circuit is getting "uncharged" (or "discharged?) if you like – Eugene Sh. Oct 12 '17 at 18:49
  • *The whole idea of the ground is that it cannot become charged* **Nonsense**, if I charge a metal object the ground gets discharged. The **total** sum of charge must remain constant. – Bimpelrekkie Oct 12 '17 at 18:50
  • @Bimpelrekkie https://en.wikipedia.org/wiki/Ground_(electricity) a "ground" is usually idealized as an infinite source or sink for charge, which can absorb an unlimited amount of current without changing its potential – Boris Oct 12 '17 at 18:52
  • *current without changing its potential* That is correct and I'm correct as well, why is that? Because the earth is much much larger than my object so on the whole earth the charge displacement makes little difference but it does on my small object. – Bimpelrekkie Oct 12 '17 at 18:53
  • Anyway. Let's go back to our favorite water-and-pipes analogy. Consider battery as a pump and the ground as a reservoir with a very high(or low, or whatever) water pressure. will connecting the closed pipe/pump circuit cause any water flow to/from that reservoir? – Eugene Sh. Oct 12 '17 at 18:54
  • *which can absorb an unlimited amount of current without changing its potential* And where does this charge come from? Is it made somewhere? Nope, charge is an electron taken away from it's atom or an Atom from which an electron has been taken away (Ion). – Bimpelrekkie Oct 12 '17 at 18:55
  • What specifically don't you understand? My answer assumes you have the circuit as drawn. The one from @Trevor recognises that in the real world there are parasitic components that are not shown on the circuit diagram. Both are correct if you take them in the sense intended. Please explain where you need further clarification. – Warren Hill Oct 12 '17 at 19:49
  • @Boris You are right. There is a leakage of electrons flowing out of your circuit due to the random movement of electrons; however, this is being cancelled by the same number of electrons flowing _into_ your circuit as well. There is no current because there is no _net_ flow of electrons due to the earth and the negative battery terminal being at the same voltage potential. – jstarr Oct 12 '17 at 20:00
  • @jstarr why would electrons return? There's an EMF pushing charges down the wire from + to -. The questions is why it is pushing it to the return and not to the ground. Both paths are at the same potential – Boris Oct 12 '17 at 20:06
    @Boris, no they are not at the same potential, and even if they were, the bottom of the battery is negative with respect to the top and the electrons move around the circuit from the bottom to the top. No extra electrons are added or removed from the circuit, as would be the case if something crossed the ground connection. – Trevor_G Oct 12 '17 at 20:38
  • Must be a lot of bent pennies in here.. none of them seem to be dropping.. That tells me the OP has some basic concept wrong in his head that wont be answered till we know what it is. – Trevor_G Oct 12 '17 at 21:08
  • The question "2" is about when you have **two** ground connections. – user253751 Oct 13 '17 at 01:01
In reality there is current in the ground connection, but not enough to measure above ambient noise level.
Below is your equivalent circuit.
ADDITION
As such we normally ignore that leakage current in DC circuits. So let us look at your question another way.
For the moment consider what would happen if an electron fell down that "drain" to ground. What happens to the rest of the circuit?
Suddenly it will have a missing electron and will have a net positive charge. The ground now has an extra electron and has net negative charge. That means there is a reverse voltage on the ground wire which will immediately cause the electron to return to the circuit.
The opposite would happen if somehow an extra electron were to arrive from the ground. The circuit would be at a negative potential and ground would be positive. The visiting electron would be immediately repelled.
In actuality, that returning force is what prevents the electrons from crossing the connection in the first place. It is a self stabilizing state.
Trevor_G
  • 46,364
  • 68
  • 151
  • Hmmm - I'm not sure about the precision of your 1e16 resistor ... – brhans Oct 12 '17 at 18:46
  • @Trevor Air resistance? And if the circuit is enclosed in vacuum? And only ground wire is "piercing" the vacuum chamber. – Boris Oct 12 '17 at 18:48
  • @brhans ya that was a very rough approximate and will vary widely... it's the exponent that is important though .. huge # = b.all current ;) Things change a lot when its a high frequency voltage source though. – Trevor_G Oct 12 '17 at 18:52
  • @Boris indeed, in a vacuum you still have an impedance.. but it gets complicated. – Trevor_G Oct 12 '17 at 18:53
  • @Boris, the point is you need a loop back to a higher potential for current to flow through that wire. Now you will get a loop, be that through leakage in air or the impedance of a vaccum, but the current that will flow round that loop is so small you can take it as zero for a DC circuit. A high frequency power source though would be different. – Trevor_G Oct 12 '17 at 18:58
  • @Trevor I think for current to flow there must be a potential difference. period. The loop is need by any reasonable EMF generating device to sustain this potential difference. – Boris Oct 12 '17 at 19:01
  • @Boris that is correct, for current to flow, you need two things, a loop and a potential difference. – Trevor_G Oct 12 '17 at 19:05
  • I'm still not seeing a ground current here. As \$R_{air}\$ is in parallel with \$R_2\$ so there is no current in the earth. If it were the case that you had two separate ground connections then some current might flow out of one but it would be flowing back into the other as the current out of the battery would also have to flow into it to avoid breaking Kirchhoff's current law. – Warren Hill Oct 12 '17 at 19:16
  • @WarrenHill it does not matter. The leakage resistance from the top of the battery through air and back through ground to the bottom of the battery exists. It may be negligible, but it is still there. Kirchoffs laws still hold. – Trevor_G Oct 12 '17 at 19:19
  • @Trevor I know I'm being pedantic here but this is only true if there are separate grounds the voltage from the top of the battery finds a path to ground via the air. Agreeably this is negligible and the ground as \$R_{air}\$ is very large. This ground connection is not necessarily intended it may be, for example the earthed case of a nearby computer. but this current has to be returning through the the intentional ground connection, or via another route to ensure we don't break KCL. Current out of the battery must equal its return current. – Warren Hill Oct 12 '17 at 19:29
  • @Trevor I would accept your answer know as with two connections there is an an alternative return path – Warren Hill Oct 12 '17 at 19:30
  • @WarrenHill yes indeed there are a myriad of high impedance paths. But since the OP is specifically asking about current in his hard connection to ground, it's the only one I want to mention here. and yes, in reality, top of battery back to that wire will have taken numerous routes to get there a few of which come up that ground link.. but that is not pertinent to the question. – Trevor_G Oct 12 '17 at 19:31
This is explained by Kirchhoff. He has two laws: the voltage law and the current law.
I won't explain the voltage law, as that is not what your question is asking, but the current law simply states:
The sum of all currents into a node is zero
alternatively:
The sum of all currents out of a node is zero
What this means in the case of your simple circuit is that the current \$I_1\$ flowing out of the top of your battery is equal to to the current \$I_2\$ flowing into the battery.
Since the battery and resistor are in series with the resistor, then the current flowing into the bottom node via the resistor is \$I_1\$.
Let's call the current flowing to earth \$I_3\$.
\$I_3 = I_1 - I_2 = 0 \$ since \$I_1\$ = \$I_2\$.
Andrew Morton
  • 2,389
  • 26
Warren Hill
  • 4,780
  • 32
  • Not sure Kirchhoff is applicable here as adding earth connection breaks the assumption of "Lumped element model" Kirchhoff is applicable to. Especially the second assumption about the constant charge as earth effectively makes the charge "dissapear" from the circuit. – Boris Oct 12 '17 at 20:14
In the circuit from your question, the earth ground connection function is of a reference point, i.e. a zero potential point. From this point, you can specify all voltages in circuit nodes. It's a convenience for the analysis, say, nodal method.
There isn't relation with current. Is a convention to assign a node as a zero-potential node.
Martin Petrei
  • 3,034
The circuit diagram shows no elements that would cause a current to flow to ground. If current DOES flow to the 'earth ground' node, is it positive? Negative? AC? DC?
Simply put, this circuit doesn't create any current output, unless other circuit elements exist, which are not shown. If there's a storm cloud, and lightning strikes, there WILL be current to ground. That, however, isn't part of the schematic, so isn't part of the equation. Thus, we're left with 'zero' current predicted.
Whit3rd
  • 7,177
