I've a 12 volt 1 Amp rated adapter and would like to hook up 2 12 volt 0.18 Amps Dc motor in parallel circuit to power them up, would the over rated amps effect my dc motors and if so how can i reduce Amps without reducing its volts ?
Asked
Active
Viewed 1,294 times
Let's use another example: I have a 100 W motor that I'm going to plug into the Irish national grid which has a capacity of 5 GW at peak capacity. Do you think it will burn out my motor?
Answer: No. The motor will draw the current it requires. This current is limited by the resistance of the motor.
Back to your question:
Would the over rated amps effect my DC motors and if so how can I reduce amps without reducing its volts?
Transistor
- 168,990
- 12
- 186
- 385
Since the OP was asking about current this answer would be better if you used amps rather than watts. – stib Oct 12 '17 at 12:52
2 * 0.18 is less than 1 amp so it will be fine. The extra capacity from the adaptor will not be a problem.
Solar Mike
- 6,319
- 1
- 12
- 28
What if the same goes for series circuit, would there be any change than..? – Illucifer Oct 12 '17 at 09:03
