I have been reading quite a lot on the subject in the past hour and I don't seem to be getting an answer, just about amps. I have a 2 watt rated ball valve, and I have a 12v dc 1 amp power supply. W = a * V. So 12 watts power supply? Would it burn out the ball valve?
Asked
Active
Viewed 120 times
That is just voltage and amperage ratings, I want to know how they combine from the wattage. It doesn't answer that – user140052 Oct 07 '17 at 22:47
The amount of power required depends on the load. Your job is to simply provide a power supply that can provide enough power at the device's rated voltage. P=VI, right? So at the rated voltage, the electrical requirement can be described in either Amps or Watts. Whichever value you have, you can easily calculate the other one. – bitsmack Oct 07 '17 at 22:59
What is the voltage of the ball valve? You need to match voltage so if it isn’t 12 volt, forget using that power supply. Assuming it is 12 volt, 2 Watts = (2/12) = 0.17 amps. If you read the linked answer, you know that the power supply amperage must equal or exceed the load amperage. Your 1 amp power supply is fine. – DoxyLover Oct 07 '17 at 23:01
Let's use another example: I have a 100 W light bulb that I'm going to plug into the Irish national grid which has a capacity of 5 GW at peak capacity. Do you think it will burn out my bulb?
Answer: No. The bulb will draw the current it requires. This current is limited by the resistance of the bulb filament.
Back to your question:
No. It will provide as much power as the solenoid valve requires. The current (and therefore the power) will be limited by the solenoid resistance.
Transistor
- 168,990
- 12
- 186
- 385
