15
How to automatically retrieve, given a Digi-Key part number, information such as Manufacturer, Manufacturer Part Number, Description, etc. Perhaps parsing the GET http respose to:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=DK_PART_NUMBER
(thanks to angryee for the correct parameters)
Where DK_PART_NUMBER is the Digikey part number.
Does anybody know if they have a web service or simply a better interface for this?
After asking this question I decided to go ahead and write something that did some basic fetching from Digikey:
dk_pn = '587-1962-1-ND'
from urllib import urlopen
from sgmllib import SGMLParser
headers = ['Digi-Key Part Number',
           'Manufacturer',
           'Manufacturer Part Number',
           'Description',
           'Lead Free Status / RoHS Status',
           'Operating Temperature',
           'Standard Package',
           'Price Break',
           'Unit Price',
           'Extended Price']
class DK_Parser(SGMLParser):
    def reset(self):
        SGMLParser.reset(self)
        self.last_td = ''
        self.inside_th = False
        self.inside_td = False
        self.grab_data = False
        self.part_info = {}
        self.hdr_index = 0
        self.row_hdrs = []
    def start_tr(self, attrs): # row
        self.first_header_in_row = True
    def start_th(self, attrs): # header cell
        if self.first_header_in_row:
            self.first_header_in_row = False
            self.row_hdrs = []
            self.hdr_index = 0
        self.inside_th = True
    def end_th(self):
    def start_td(self, attrs): # data cell
        self.inside_td = True
    def end_td(self):
        self.hdr_index = self.hdr_index+1
    def handle_data(self,text):
        text = text.strip()
        if self.inside_th:
            if text in headers:
                self.row_hdrs.append(text)
                self.last_td = ''
                self.grab_data = True
            else:
        elif self.inside_td and self.grab_data:
            if self.hdr_index:
                self.last_td = ''
            if self.hdr_index < len(self.row_hdrs):
                self.last_td = self.last_td + text
                self.part_info[self.row_hdrs[self.hdr_index]] = self.last_td
dk_url = 'http://search.digikey.com/scripts/DkSearch/dksus.dll'
dk_params = '?Detail&name='
sock = urlopen(dk_url + dk_params + dk_pn)
parser = DK_Parser()
parser.feed(sock.read())
sock.close()
parser.close()
for k,v in parser.part_info.items():
    print k,":",v
Only the first data line of the the [price break/unit price/extended price] table is captured.
apalopohapa
  • 8,419
  • 39
    Digikey now has web services for searching and ordering, and has some sample code for this: https://services.digikey.com/ – apalopohapa May 06 '13 at 20:16
    [BeautifulSoup](http://www.crummy.com/software/BeautifulSoup/) is probably the best HTML parser for python. It's MUCH nicer then the built-in stuff. – Connor Wolf Jan 14 '14 at 19:30
  • Could be helpful for custom Chrome search engine. https://www.groovypost.com/howto/add-custom-search-engine-chrome/ – johny why Jun 12 '22 at 17:04
6 Answers6
You'd want to use the detail option instead of the keyword. Like this:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=458-1003-ND
That returns an HTML page which is text which can be parsed. It's all in table format so you can create a list of terms you're interested in and parse out the values. I can see a parts list script that takes in a list of parts and the values you want to retrieve (ie, Voltage, Max Current, or however Digikey lists it) and then make some Python to read the part number, grab the page, parse out the info and stick it in a CSV, database or HTML file. I've been thinking of something similar and it doesn't seem too hard. Well, hard enough to stop me from whipping it out right now anyway :)
AngryEE
  • 8,669
Perhaps you could do it through Octopart's API?
pingswept
  • 12,581
  • 64
    From their [documentation page](http://octopart.com/api/documentation), it looks like you can filter on supplier (DigiKey, in this case), although I just searched for a handful of parts on DigiKey's website and Octopart didn't mention DigiKey in the results. – Flyguy Jul 08 '10 at 12:00
    Apparently Digikey has specifically asked them not to inlude them in their search. – apalopohapa Sep 27 '10 at 05:36
    That has since changed, Digikey is included in the results.Previously, this year even, Octopart did not show search results from Digi-key. It seems they have worked something out with Digi-Key and now Octopart displays results from Digi-key – Kortuk Jan 11 '13 at 00:25
    I am running my own python script directly against Digikey and querying Octopart API and i am getting different results. Also, coding directly against digikey i can follow alternate packaging links for the same part, i dont think Octopart maps this properly. – kert Apr 12 '14 at 17:46
The current best answer is https://services.digikey.com/ as 'The Digi-Key Search Web Service (SWS) and Ordering Web Service (OWS) provide clients with real-time access to Digi-Key’s vast product database and ordering system.'.
What you're doing is "screen scraping", which is vulnerable to breaking as DigiKey updates their website.
Bryce
  • 859
  • 26
    Yes. This was asked in 2010 when the those services didn't exist yet. "screen scraping" was the best solution back then. Of course, *any* technique is vulnerable to breaking when the systems/interfaces/API get updated. – apalopohapa May 07 '15 at 20:16
If you keep your BOM as a MS Excel spreadsheet, you can pull the prices directly into a worksheet via Data->Get External Data->From Web. I'm using Excel 2010. Here is a macro that I made using the macro recorder.
Sub addDigikeyPriceExample()
    'http://www.digikey.com/product-detail/en/MANUFACTURERPARTNUM/DIGIKEYPARTNUM/PACKAGINGNUM ?
    With ActiveSheet.QueryTables.Add(Connection:= _
        "URL;http://www.digikey.com/product-detail/en/SI4707-B20-GM/336-2147-ND/2686997" _
        , Destination:=Range("$A$1"))
        .Name = "2622997" 'make random number?
        .FieldNames = True
        .RowNumbers = False
        .FillAdjacentFormulas = False
        .PreserveFormatting = True
        .RefreshOnFileOpen = False
        .BackgroundQuery = True
        .RefreshStyle = xlInsertDeleteCells
        .SavePassword = False
        .SaveData = True
        .AdjustColumnWidth = True
        .RefreshPeriod = 0
        .WebSelectionType = xlSpecifiedTables
        .WebFormatting = xlWebFormattingNone
        .WebTables = """pricing"""
        .WebPreFormattedTextToColumns = True
        .WebConsecutiveDelimitersAsOne = True
        .WebSingleBlockTextImport = False
        .WebDisableDateRecognition = False
        .WebDisableRedirections = False
        .Refresh BackgroundQuery:=False
    End With
End Sub
imjosh
  • 245
Here's sample code in python, ruby and JS to do this with Octopart's API
http://octopart.com/api/docs/v3/overview#bom-matching
You can filter out for Digikey at the application level.
W5VO
  • 18,303
  • 63
  • 94
Octopart
You can create a custom Chrome search engine.
  1. go to Chrome settings
  2. click search engine > Manage search engines and site search
  3. under Site Search, click Add
  4. Enter
    Search engine: Digikey
    Shortcut: di
    URL: http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=%s
To test:
  1. Open a new tab
  2. In address bar type di and press spacebar
  3. Enter desire part number
https://groovypost.com/howto/add-custom-search-engine-chrome
johny why
  • 166
