After running power flow solution using Newton Raphson, I have been trying to vary the voltage of a PQ bus by adjusting the reactive power at bus. If my desired voltage is higher than actual, then I am increasing the net reactive power flow (Q=Qg-Qd; I increase Q) and vice versa. Normally to boost voltage, I must supply leading reactive power. And so far what I have seen is, leading reactive power has negative sign. But here in my scenario, I am increasing Q (Q=Qg-Qd) to boost voltage. So what is the sign convention used here for the reactive power? Could someone please share me a link or if possible explain me the sign convention used for reactive power? I am so confused that I am not even able to frame this question clearly. Sorry for such a lengthy and improperly framed question.
@StewieGriffin: is there a sign convention on Qg, Qd? I would expect Qg >= 0, Qd <= 0? – rrrrr Jan 29 '19 at 19:09
There's no such thing as leading or lagging reactive power. You can increase or decrease the amount of reactive power you introduce in the system, by inserting capacitors, coils, transformers, cables, filters or change the voltage/current angle of generators, inverters and so on.
The amount of reactive power is what determines if the current is leading or lagging the voltage.
The sign convention of reactive power is not really a thing, it's a positive sign if you inject it, and a negative sign if you consume it.
Where you might encounter problems with the Newton Rhapson's load flow is with the equation for real, reactive and apparent power equations that you calculate using the current and voltage:
The apparent power is the voltage times the complex conjugate of the current, meaning you change the sign of the imaginary part of the complex number (or change the sign of the angle). If you inject current with a leading angle, you'll get negative imaginary part, and vice versa.
Since the reactive power is the imaginary part S, the sign is opposite of what you get if you simply multiply voltage and current, which is the intuitive thing to do.
- 1,547
- 3
- 19
- 36
