37
Why do Arduino boards ship w/ 16MHz crystal instead of 20MHz? They are spec'ed for operating at 20MHz, after all.
I guess there are a few advantages to running more slowly (lower power consumption, longer life), but I must be missing something.
JellicleCat
  • 649
    This was also asked in the old Arduino Forum: http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1240016311 – vicatcu Jun 03 '12 at 19:22
    Note that this 25% application speed gap can be gained many times over with proper programming. I try to stay away from any IC's extreme limits, though. – tyblu Jun 03 '12 at 19:29
I'd buy into the answer on the Arduino Forum:
The original ATmega8 Arduino ran at 16MHz, which was the top rated clock speed for the ATmega8 cpu used. When "upgraded" to ATmega168 (with a 20MHz top cpu speed), the clock was left at 16MHz (probably) because the designers thought that more people/code would have backward compatibility issues with a new clock rate than would benefit from the extra 25% cpu performance. I certainly think they were right...
vicatcu
  • 22,499
  • 79
  • 155
Actually, one of the best reasons I've heard is that the UART can perfectly match 1 Mbit and 2 Mbit rates when running at 16 MHz, but not when running at 20 MHz. There are a number of devices that have 1 and 2 Mbit UART inputs, such as the Dynamixel line of robot servos.
Jon Watte
  • 5,650
  • 26
A third point is that the Low Power Crystal Oscillator of the ATmega168 and ATmega328 is not working above 16 MHz. So if you have a 20 MHz crystal connected to the XTAL pins, you have to use the Full Swing Crystal Oscillator which will consume more power (or use no crystal at all).
Pascal Rosin
  • 203
