I have a STM32F103C8T6 (aka blue pill) and worked with it.
Sometimes - due a reason I don't understand - after debugging it (using Eclipse), the connection is lost and I cannot start a new debug session.
The only thing to do is the following time consuming procedure:
  • Close Eclipse
  • Start ST-Link Utility
  • In the menu ST-LINK/Firmware Update, selecting button Device Connect (to see if the ST Link stick can connect).
  • In case of an error, reinsert it (Windows shows Unknown USB Device) and redo the previous step
  • In case of no error, it shows the version: V2.J27.S6 STM32+STM8 Debugger
  • Than on the STM32 I have to press and hold the reset button
  • Select the menu option Target/Erase Chip
  • Release the button (in time, otherwise repeating the previous step)
  • Than the chip is erased.
  • Than start Eclipse again and I can continue
This is already a very tedious operation... is there a better solution? Or by what reason the debugging session causes the STM32 to lose the ability to start a new debugging session?
And even than in some cases I get the following error when trying to debug:
23:23:02 : Can not connect to target!
                  If you're trying to connect to an STM32W1xx device, please select Normal or HotPlug mode from Target->Settings menu.
                  If you're trying to connect to a low frequency application , please select a lower SWD Frequency mode from Target->Settings menu.
23:23:03 : No target connected
The Eclipse project configuration file fragment:
# use software system reset
reset_config none
set CONNECT_UNDER_RESET 0
Michel Keijzers
  • 13,867
  • 69
  • 139
I found the problem of one of the questions, so I added it for other people's reference, since it is a non-trivial default:
When using the STM32CubeMX which I do, whenever a project is made, by default the following item is selected:
  • SYS, Debug: No Debug
This causes that the following code is generated in HAL_MspInit:
__HAL_AFIO_REMAP_REMAP_SWJ_DISABLE();
As soon as the debugger passes this command (which is one of the first commands in HAL_Init which is called in main(), the debugger loses connection and even a new debug session cannot be started.
It can be easily fixed with setting to
  • SYS, Debug: Serial Wire
(which is also called SWD: Serial Wire Debug, and is supported by ST Link 2).
__HAL_AFIO_REMAP_SWJ_NOJTAG();
And debugging works as usual.
Michel Keijzers
  • 13,867
  • 69
  • 139
