I have been looking into making a voltage controlled oscillator using varicap diodes, however I have had hard time simulating the diodes in spice.
Would anyone here have an idea how this would be done?
Thanks in advance
Thanks in advance
Maybe you can solve your problem by using variable capacitance models (intially found on the LTSpice Yahoo group I think ).
The equation governing the charge and voltage of a capacitor is \begin{equation} Q = CV \end{equation} In LTSpice, you cannot change the capacitance value. Rather you specify the charge of the capacitor. Hence, you specify your capacitor value as: \begin{equation} q = V{(\text{your capacitance node})} \cdot x \end{equation} where x is the voltage over the capacitor in question. This is covered in the LTSpice Help file under C. Capacitor
