I have designed a circuit to measure 0-12.2V and Scale it to 0-10V from a PLC input to read. I have put an LM741CN in the circuit as a voltage follow to isolate the test circuit from the measurement circuit.
All is well except that when I input less than 2V into the op amp it stops following the voltage and continues to output about 2V I have input 0V into it and I still get about 2 volts out.
I can't find anything on the spec sheet about there being a minimum voltage output. What am I doing wrong?
