What's the difference between the following two circuits? Note that the capacitors are DC blocking, and the FET is on.
I understand that usually, the load is connected to ground. But what would happen if it was connected to the negative DC bias? What about the positive DC bias? Does the mode (constant-mobility, constant-velocity, ...) make a difference? I saw this circuit in a small-signal analysis problem.
Of course, if the capacitors are NOT high enough that they become an open circuit at DC and a short circuit in AC, then that will affect the circuit in obvious ways. I'm asking about any other effect this would have.
