I am given this question The given question as is
I have 2 questions:
1) Is my work wrong? I am assuming so since I am getting some funky answers. If I am wrong, will you please point out what I should have done differently?
2) Since he didn't add a ground I figured I would have to consider the entire bottom wire as + 0.2I_0 because of the dependent source, but would I also have to consider my external voltage (V_x) in some way? If so, how would I add it into my work?
Problems I had with this question:
1) There is no ground, I am not familiar with problems like this.
2) I was not sure what equations I needed for all my unknowns. The equation that feels most like it doesn't belong is Equation 2, but I could not find any better approach.
Thanks!
Here is my attempt to solve for R_th: Attempted Solution
Smeboo
  • Your first equation has a term \$V_a / 0.25\$ but there's no 0.25 ohm resistor connected to node A, so this is likely an error. – The Photon Sep 07 '17 at 21:01
  • Maybe you got confused because the original problem labelled two nodes as 'a' and 'b', but then you defined a different node as 'a' and the one that was originally 'a' you re-labelled as 'b'. Keep your node labels straight and it will be much easier to come up with consistent equations. – The Photon Sep 07 '17 at 21:03
  • I definitely goofed that up. I will fix that ASAP and post a new but I still get NaN values in Matlab – Smeboo Sep 07 '17 at 22:29
First of all, you can have "ground" wherever you want. In this case, "ground" is just a theoretical reference point for all of your voltages, a point at which you say the voltage (or potential difference) is 0 and all other voltages are compared to. The best place would certainly be node b.
The fact that you have a voltage source positioned "upside down" has no effect on this, it just means that the voltage on the other side of the source will be negative.
Next, you should look into superposition. It makes things pretty easy to solve. I would start with the known voltage first:
  • Treat the dependent voltage as a short
  • Find out the voltages at all the different points
  • Lump all the resistances together, giving a single 4/31 ohm resistor
  • Get the current through this due to your source, which is 7.75A
    -Now find the voltages due to the dependent voltage
simulate this circuit
  • The second diagram is just a rearrangement of the first, making it obvious that R4 and R3 form a potential divider. This means v2 is -1/4*0.2Io, and v1 is -0.2Io.
  • Now we can sum the superpositions, giving a V2 of ((-Io/20) + 0.25Vin)
  • The current through R4 is equal to Io, so it would be useful to get this. We know the voltage on both sides, so we just do Io=(0-((-Io/20) + 0.25Vin))/0.1
  • After a bit of maths, we get Io=-5Vin
  • This means that V1=Vin
BeB00
  • 5,303
  • Superposition doesn't apply here since there's only one independent source (the test source to be applied to the port). – The Photon Sep 07 '17 at 20:57
  • I'm pretty sure you can still apply superposition even with dependent sources, as long as you stick with variables instead of absolute voltages until you sum all the superpositions – BeB00 Sep 07 '17 at 21:07
  • Say you zero out all the sources except the dependent source. Now whatever is the input controlling the dependent source will be a 0 (voltage or current). So the dependent source output will be 0. Not very useful, nor will it give you a correct result. More detail [here](https://electronics.stackexchange.com/q/162436/6334) – The Photon Sep 07 '17 at 21:10
  • I'm not quite sure what you mean. Yes, if you connect 0V across the terminals, the dependent source will be 0V. When I simulate this circuit, V1 does seem to be equal to Vin. That link doesn't really explain why you shouldn't use superposition for dependent sources – BeB00 Sep 07 '17 at 21:12
  • https://electronics.stackexchange.com/questions/107435/superposition-principle-dependent-sources-treated-as-independent-sources – BeB00 Sep 07 '17 at 21:41
  • I'm with Vladimir in the coments over there. That may be a valid way to solve circuits, but it's not what we usually call the superposition method. – The Photon Sep 07 '17 at 21:45
  • Yeah, I always learned that you can't use super position with a dependent source. Which makes it a bit challenging to follow your work. I assume you are still using the external source method but just solving with a different form of super position (than what I learned) correct? – Smeboo Sep 08 '17 at 00:25
  • It's still using the superposition of voltages, you just don't try to solve any equations until you've finished the superposition. – BeB00 Sep 08 '17 at 01:15
  • https://eprints.soton.ac.uk/271202/1/superposition.pdf Damper's paper is a pretty good read – BeB00 Sep 08 '17 at 01:33
