Below, is the SD card reader I would like to use. It's using SPI.
On an Arduino I got it to work (using SPI).
However, I want to test it on a STM32F103C8T6, and later use it in STM32F407VET6. However, I see both the F1 and F4 can use the FATFS file system, which I need, but only the F4 has the SDIO peripheral (the F1 has not).
But since it is an SPI SD reader, I don't think I will need SDIO anyway. However, still I wonder how to control it. Should I find out myself what SPI commands I should sent or are there better ways? Or should I get an SD card reader without SPI?
For my project, the requirements regarding SD are pretty low. I want to read one file from it, from max. 128 KB, and I don't care much about the speed (within one second is good enough). Maybe later I want to write to it too (also no fast time restrictions).
What would be the easiest way to read from this type of SD card reader?
I would rather use CubeMX and System Workbench (Eclipse).
SD card reader
Michel Keijzers
  • 13,867
  • 69
  • 139
    This is not a SD-Card reader with SPI Interface, but a breakout board from SD-Card to a pin header. SD-Cards have a SDIO and SPI interface as standard. – Arsenal Sep 01 '17 at 08:07
    @Arsenal ... Thanks Arsenal, in this case I think SPI is good enough, especially if I can combine it with FATFS (I already asked for an example to filo) – Michel Keijzers Sep 01 '17 at 09:37
The easiest way if of course SPI. I am not sure if SPI protocol is the only one publicly available.
Software side - use FATFS, there is an STM32F100 demo code already.
filo
  • 8,801
