So I have some old dynamo, and I want it to power my GPS navigator.
But first of all I want to calculate its maximum power it can deliver.
Setup: two wires are soldered to dynamo on one end, on other end they are soldered to 5 Ohm resistor. True RMS multimeter is measuring AC voltage across the resistor.
Results: on my normal speed it showed 3 V. On my maximum speed 3.15 V.
3*3/5 = 1.8 W
Dynamo is labeled 3 W, measured resistance 33 Ohm.
The copper wires are near 0 Ohm. All joints are soldered. There cannot be any losses.
Question 1: Did I do right to calculate maximum dynamo's power?
Question 2: Where is 1 W lost?
JRE
  • 67,678
  • 179
Qeeet
  • 319
  • The 3W marking is a very approximate rating. Why did you use 5 ohms as the load? As @jasen describes in his answer you need to match the load to the generator to get maximum power. This optimum load will change with RPM. – Kevin White Aug 26 '17 at 20:53
Inductive voltage regulation
The traditional bicycle dynamo's (see note) output voltage will vary roughly proportional to speed. If this problem is not addressed the lamps - its intended load - will be very poor at low speeds and the bulbs will blow at high speed. The solution is to design the system - dynamo and lights - as a complete package with enough series inductance built in to the dynamo to regulate the terminal voltage.
Note: Technically the bicycle generator is an alternator since it outputs AC. Dynamos output DC.
Figure 1. Standard dynamo arrangement showing internal series resistance and inductance.
The impedance of an inductor is given by \$ Z = 2 \omega L = 2 \pi f L \$. This shows that the impedance is proportional to the frequency which, of course, is directly related to the speed of the bike. If designed correctly the lamps will turn on to a reasonable brightness at quite low speed and will be noticeably brighter at high speed but without blowing the lamps - the reason being that the inductors and lamps form an L-R voltage divider.
Since the specification is 3 W at 6 V we can calculate from \$ P = \frac {V^2}{R} \$ that optimal load is given by \$ R = \frac {V^2}{P} = \frac {6^2}{3} = 12 \; \Omega \$.
If that works you might wish to chart power as a function of velocity. It should be fairly constant.
There are various articles on the web from folks who have tried to figure out the characteristics of various alternators.
Figure 2. Comparison of various brands and models as a function of speed. Note that the load is not specified. It can be assumed that it is the same 2.4 + 0.6 W front and rear bulb configuration. Source: Myra-Simon.
Transistor
  • 168,990
  • 186
  • 385
Dynamos are inherently current-limited.
The current limit is because the permanent magnet has a fixed magnetic strength this places a limit on the current it can induce in the dynamo windings.
There is no voltage limit, the faster you ride the more open-circuit voltage the dynamo will provide.
To get more power out use a higher resistance (and ride faster) maximum output will be by matching the dynamo resistance and riding at extreme speed, maximum practical output will likely be somewhat lower.
to get closer to 3W output try 8 ohms.
