the company i work for has tasked me in rebuilding an old LED sign we had replaced. (newer led rgb version) The driver board that was in the sign has gone out. So i am trying to rebuild the driver boards.
The boards are 8x8 for a total of 64 leds per board and 32 boards.
I have done multiplexing of led's before the problem i am running into is that the board is NOT set up as the following....
however, they are set up as the following
As you can see they each have their own pin but share a common ground. I am having a problem finding something that can control that many leds at one time that can be expanded to 32 other panels.
I found the Mux Shield II over at sparkfun but i dont think its big enough to do what i want. What am i missing there has got to be something out there that will control 64 leds at a time!
Also the led boards are RED led's only. no RGB
