I have read a good discussion about the safety of an isolated transformer.
However, in my understanding, the secondary side of the isolated transformer is floating, so will it has a high potential difference with the Earth ground? If it does, because I am at Earth potential, will I get shock when I touch the secondary side?
eepty
  • 279
The secondary of the transformer is floating, so it's not referenced to anything (a potential difference to earth ground does not exist). You will not get a shock if you touch one terminal. Touching both terminals, however, is not recommended, as a voltage exists across them.
uhours
  • 661
