I'm looking into whether an ungrounded metal box provides good/bad EM shielding.
This thread seems like a definite "good", for reasons of the box acting as a faraday cage : How much shielding does an ungrounded metal box provide?
But when a similar question is asked about ungrounded cable shielding, I am finding some "good" and some "bad". Here is a good: Does an ungrounded shielded cable shield at all?, and #3 of one of the answers is bad: Cable type and decreasing EMI/RFI
"If you don't ground the shield, then it is just a great receiving "antenna" for collecting all your noise, interference, EMI, RFI, etc. And then it is a great method of caacitively coupling all this noise right into your signal wire(s). It is almost worse to have an ungrounded shield than to have no shield at all."
So doesn't an ungrounded cable shield also act like a faraday cage? Is it the fact that the cable shield is physically located closer to the wires that you have to start worrying about capacitive effects?
With that logic, would it be safe to say that an ungrounded metal box provides good EM shielding granted that the electronics you are trying to protect are physically located at a sufficient distance away from the walls of the box?
user2913869
  • 1,041
There is a big difference between mounting self-powered electronics inside an ungrounded conducting box and an ungrounded shield on a cable. Of course the electronics inside the box is protected but, if those electronics were fed from an external power source that is unprotected (i.e. not in the same "faraday cage") then you stand to make no gain.
So this is why you should ground the shield on a coax or twisted pair cable - an ungrounded shield only prevents differential voltages appearing on the signal cables. However, an ungrounded shield does not prevent common mode signals appearing on the signal wires - you must ground the shield to remove these.
I have to disagree with this - the limited benfit of an ungrounded shield is that it applies the same interfering signal shape and amplitude to both signal conductors like this: -
And, providing you use a differential amplifier at the receive end, that interference is cancelled. You don't need to transmit a balanced signal from the send end but you do need to have equal wire impedances to ground at the send end and, by inference, you need equal impedance balance at the receive end.
The problem with the shield being ungrounded is the level of interference "given" to both balanced wires is much higher than in the case of a grounded shield and this means the receiver has to deal with a bigger common-mode noise signal and this is going to be harder to remove.
Would it be safe to say that an ungrounded metal box provides good EM shielding granted that the electronics you are trying to protect are physically located at a sufficient distance away from the walls of the box?
No, not really - everything inside the box is protected - everything is being wobbled up and down together and each node-to-node voltage remains the same as if there were no interference - the problem comes when you make a connection to the circuit inside the box.
