Looking at building an audio amplifier; many good example circuits and example tutorials based on the below simple common emitter circuit. All of them I have found so far help to size the biasing resistors and the collector and emitter resistor, along with the capacitors. Using the rule of thumb for designing this style of amplifier of 1/2VCC at the output to the speaker, I would want a 12V drop across Rc. However, all of the tutorials I have read assume the collector current and then size Rc based on the two known parameters. I am struggling with what the collector current should be though. If my speaker output is a known 8 ohm, 3 watt, can I size the collector current based on that load? But some of the collector current will also flow through the transistor (KCL), so how do I control my load current? Or does it not work that way and I can only control voltage gain across the amplifier? Since power is dependent on both voltage and current, and taking the voltage at the collector to be 12V, I would have a current at the speaker of 1.5A, which equates to a power draw of 18 watts. Obviously, I am not thinking about this correct. So if I size everything around a max current below 3 watts (which would be 0.6A at 8 ohms), would that dictate my collector current? But again, 0.6A would go to the speaker, but how much flows through the transistor? I am okay with following the design "rules-of-thumb" for a CE amplifier for biasing, voltage gain, frequency response, etc.. but I am really struggling grasping this one part. I could just make an assumption of 100 mA through the collector, but I would have to think that the collector current can be engineered, not assumed.
Edit: Let me try again, looking at this example question: Common Emitter Audio Amplifier 1) How did the OP determine a collector current of 1.26 mA (24V/8k = 3mA, 12V/8k = 1.5 mA, 24V/11k = 2.2mA, 12V/11k = 1.1mA....)?
2) How much of that collector current would flow to the load? Ultimately, I understand that a push-pull or class AB amplifier would work significantly better. I am just trying to understand this first piece so I can analyze more complicated circuits better.
nu77p01nt3r
  • 168
    To properly drive the speakers we are using a emitter follower or the complementary version the push-pull stage. Hence the CE stage does the voltage gain and CC amplifier does the "current" gain. – G36 Aug 06 '17 at 17:27
  • The words snowflake, Hell and chance come to mind. At least put a large value capacitor between the collector and speaker to separate the DC from the AC to save the poor speaker from releasing the magic blue smoke. – JIm Dearden Aug 06 '17 at 17:58
  • I am not saying this to discourage you. You have obviously done some research. But there are many things you do not understand yet. What you have posted here will not amplify and drive a speaker, and it cannot be easily fixed up, either. My suggestion is to look into Nelson Pass's Zen amplifier. Not that Nelson Pass is a great circuit designer, but at least the Zen amplifier will work. – user57037 Aug 06 '17 at 18:30
  • @JImDearden - You are correct, I didn't draw the complete schematic. Sorry about that. I knew there was a capacitor needed at the output but since my question was totally unrelated to that, I didn't show it. I can see why it would be confusing since I showed the other ones. – nu77p01nt3r Aug 06 '17 at 22:04
  • I am pretty sure I have seen many circuits where just these component are used. I thought it was merely a Class A amplifier? Why the comments that it won't work (other than missing the output capacitor). Or is it just not very professional and won't work ideally? I don't mind adding to it to make it real-world, right now I am merely trying to understand this "building-block" if you will – nu77p01nt3r Aug 06 '17 at 22:11
  • Why it won't work. The current gain of the 2N3055 is in the region of 20 -70 for Ic about 4A. In design you take the worst case so the required base current current would be about 30 mA which means your potential divider R2,R3 would need about 300 mA (roughly 10x base current). (total 80 Ohms). This low value means your source has to be a very low source resistance and high output. The value of C1 has to be huge to get any lower frequency in the audio range. Add to that it is grossly inefficient power wise. Look for something using a class AB output (NPN,PNP) and a few more bjts. – JIm Dearden Aug 07 '17 at 10:48
  • For maximum power transfer, output impedance of the amplifier should be equal to the load impedance. So, it's safe to say that RC should be 6..8 Ohms because of the direct coupling *(note that there should be a big capacitor between output and load)* Since this is a Class-A amplifier, biasing is needed for proper operation *(e.g. at 20% of maximum load current)*. But it's quite hard to bias the circuit with that value of RC. And, as proofed in G36's answer, efficiency will be extremely low. So, the only way to go for a Class-A amplifier should be transformer-coupling. – Rohat Kılıç Aug 08 '17 at 03:54
For \$3W\$ and \$8\Omega\$ loudspeaker, you will need \$\sqrt{\frac{3W}{8\Omega}} = 0.61A\$ of RMS current (\$0.86A\$ peak)
So, the collector current should be larger than this current because the maximum positive current at the load is equal to:
$$I_{L\; max} = I_C \frac{R_C}{R_C + R_L}$$
Additional if we assume \$I_C = \frac{1/2V_{CC}}{R_C}\$
Hence \$ I_C > \frac{V_{CC}*I_{Lmax}}{V_{CC} -2I_{Lmax}R_L}=\frac{24V*0.86A}{24V - 2*0.86A*8\Omega} =2A\$ and \$Rc = \frac{12V}{2A} = 6\Omega \$
The power dissipation in the \$R_C\$ resistor is \$24W\$
And in the BJT the power dissipation is also equal to \$24W\$
As you can see the circuit efficiency is very pure
$$\frac{3W}{48W} * 100 = 6.25\% $$
But this is normal for class A amplifiers.
This is why people don't use class A as a "output stage".
We are preferring the class AB push-pull amplifier.
How does this Push-Pull amplifier work?
G36
  • 13,642
