There are various modes of operation in MOSFET transistor. The standard modes are: cut-off, linear and saturation. The FET transitions between these modes in accordance to applied bias (bias = voltages).
The equations you posted refer to a single mode of operation - Saturation. It is fine, because FETs are indeed most commonly used in saturation, but you must keep in mind that the below explanations may not be relevant to other modes (cut-off and linear).
Note that the term \$(1+\lambda V_{ds})\$ is common to both equations, therefore it may be omitted for the sake of current discussion (in fact, this term, which represents Channel Length Modulation, is completely irrelevant to your question). Therefore, let us concentrate on two forms of MOSFET I-V characteristic equation for saturation region:
1) $$I_d=\frac{1}{2} \mu C_{ox} \frac{W_g}{L_g} (V_{gs}-V_t)^2$$
2) $$I_d=V_{sat} C_{ox} W_g (V_{gs}-V_t)$$
We must also recall the definition of current (amount of charge per unit time):
$$I=\frac{Q}{t}$$
In light of this simple equation, we will be able to understand the differences between the above two equations if we can identify what is the charge and what is the time in each case.
The "usual" relation
The basic model of MOSFET (where gate is seen like a simple capacitor) states that:
$$Q_{inv}\propto C_{ox}(V_{gs}-V_t)$$
The time it takes a charge carrier to transit from source to drain (distance divided by velocity) is:
$$t=\frac{L}{v}=\frac{L}{\mu E}=\frac{L}{\mu \frac{V}{L}}\propto \frac{1}{\mu (V_{gs}-Vt)}$$
Take the above and substitute for \$I\$:
$$I \propto \mu C_{ox}(V_{gs}-V_t)^2$$
You can see that under assumption of \$v=\mu E\$ we came to a quadratic dependence on Gate-to-Source bias.
There is one fine point here: why do I claim that the electric field which accelerates the carriers is related to \$V_{gs}-V_t\$? I won't get into explanations here, but this is true for saturation mode only.
Velocity saturation relation
Velocity saturation has no effect on the inversion charge, therefore:
However, when calculating the transition time we assume that the velocity of the charge saturates. In other words: the velocity does not increase for stronger electric fields and we must replace \$\mu E\$ with \$v_{sat}\$ (saturation velocity is assumed to be constant):
$$t=\frac{L}{v}=\frac{L}{v_{sat}}$$
$$I \propto v_{sat}C_{ox}(V_{gs}-V_t)$$
This time we observe a linear dependence on \$V_{gs}\$.
Summary
The only difference in assumptions which led to the discrepancy between these equations is that in the "usual" case we assume \$v=\mu E\$ (carrier's velocity is proportional to the electric field), whereas in "velocity saturated" case we assume that the velocity saturates at some constant value and will not increase in stronger electric fields (therefore the name "velocity saturated equation").
Hope this helps.
