Knowing that I need to refine my RS485 circuitry, I've been reading. I have a series of specific questions and I hope that you'll indulge me as I describe how I attempted to follow through an application note.
Here are some basics of the serial comm system:
  • RS485
  • 115.2 kbaud, mainly limited by the microcontrollers
  • Half-duplex (1 differential pair plus ground)
  • Worst-case beginning-to-end cable run of ~80m
  • Worst-case stub length of maybe 2cm due to the PCB traces; no cable stubs
  • Daisy-chained
  • Multipoint device count of typically 8, probably no more than 20
  • Some, but not much, BER tolerance due to checksum in signalling protocol
  • All slave devices are SN65176; the master is a USPTL4.
Assume the cable I use is Belden 3106A, because it's well-specified:
  • Characteristic impedance Zo = 120 ohm
  • Velocity of propagation VP = 78%
My termination circuit has gone through a few iterations:
  1. Simple bidirectional parallel termination. Doesn't work whatsoever, due to breaking failsafe operation and producing spurious start bits.
  2. Bidirectional termination with the master side having simple parallel termination and the last slave having a circuit as described in AN-903 "Power Termination". Still doesn't work whatsoever: the parallel termination at the master presents too much of a DC load on the master and breaks failsafe operation.
  3. Unterminated master, last slave terminated with "power termination". It looks like this:
It works, but is non-ideal for at least two reasons: there is still a lot of DC load; and the master side is not impedance-matched/terminated.
For a better alternative, I consider TI AN-903 "A Comparison of Differential Termination Techniques". Based on section 2 "Unterminated",
Low speed is generally characterized to be either signaling rates below 200 kbits/sec or when the cable delay (the time required for an electrical signal to transverse the cable) is substantially shorter than the bit width (unit interval) or when the signal rise time is more than four times the one way propagation delay of the cable (that is, not a transmission line).
Since 115.2kbaud < 200kbaud, the first criterion is met. For the second criterion, to calculate the cable delay:
(80 m) / 0.78c = 342 ns
Compared to the bit width:
1 / 115.2kbaud = 8.68 μs
So this criterion is also easily met. This means that I could potentially treat the cable as not being a transmission line, and not needing impedance matching / termination. However, I want to develop a termination circuit regardless, for the following reasons:
  • It can be done cheaply
  • It's a learning opportunity
  • It increases transmission quality, even if it isn't by much
  • In case the cable run ever needs to be greatly lengthened, the system will survive
  • The TI specsheet unconditionally recommends it:
The line should be terminated at both ends in its characteristic impedance RT = ZO. Stub lengths off the main line should be kept as short as possible.
I want to pursue a modified version of section 5, AC termination. Given my system parameters, RT = 120 ohm. For CT, the app note says:
CT, on the other hand, is selected to be equal to the round trip delay of the cable divided by the cable's ZO. CT ≤ (Cable round trip delay) / ZO
Round-trip cable delay = 2 * 342 ns = 684 ns
CT ≤ 684 ns / 120 ohm
CT ≤ 5.7 nF
Select CT = 5.6 nF, the closest capacitance in the E24 (5%) series.
The app note also says:
Further, the resulting RC time constant should be less than or equal to 10% of the unit interval (TUI).
(120 ohm)(5.6 nF) ≤ 0.1 * 8.68 μs
672 ns ≤ 868 ns
So this capacitor looks OK. However, I see a (big?) problem that is not mentioned in the app note. The capacitor inline with the matching resistor makes the impedance of the matching network very unequal to the characteristic impedance of the cable.
f = 115.2kbaud / 2 = 57.6 kHz
120 ohm + 1/2πj/57.6kHz/5.6nF = 120 + 493j ohm
Should I not also add a series inductor to cancel that reactance?
493 ohm / 2π / 57.6kHz = 1.36 mH
Use the E24 value 1.3 mH. Then:
120 ohm + 1/2πj/57.6kHz/5.6nF + 2πj*57.6kHz*1.3mH = 120 - 22.9 ohm
That reactance can be brought much closer to zero with more precise inductance.
When I simulate a transmission line with the same characteristics as the Belden, and bidirectional RC AC termination, it appears to work quite well. However, if I add the inductor to cancel the capacitive reactance, there's horrible ringing.
Given all of the above, my questions are:
  • Is my math, and my interpretation of the application note, correct?
  • Why does the AN not show bi-directional AC termination? Is it valid to have AC termination on both ends of a multi-point line?
  • Why does the AN not take into account capacitive reactance when describing AC termination?
  • The PC-side RS-485 transceiver has a non-removable 4.7k pullup on line A and a 4.7k pulldown on line B, for fail-safe operation. Would this be compatible with AC termination right next to it?
Reinderien
  • 3,102
This is an interesting question :-) Thumbs up for giving it a thorough thought - I see many people still using RS485 but hardly anyone trying to understand termination (hardly anyone even knowing the basic textbook rules, actually). Also, do I understand correctly that you've tried watching the line with a 'scope? Excellent, hardly anyone does that too.
I've done an exercise on RS485 termination the other day myself... I did not consider AC termination (not in the usual differential sense), but I did focus on the role of reference ground, biasing ("failsafe") and common mode termination - as that did seem to make a difference.
The one classic deficiency of RS485 is the fact that the nodes are not guaranteed to be earth-isolated per definition. Twisted-pair Ethernet is so much easier to handle for that one reason.
Looking at your R-only terminator with failsafe in the schematic that you posted, I find its asymmetry intriguiging and bizarre. I appreciate that the net differential resistance is 100 Ohms, but I don't approve of the B line being tied by a mere 24 Ohms to GND... how did you arrive at that asymmetrical setup? I believe that the RX and TX pins in the 485 transceivers are pretty much equivalent. I would keep the biasing symmetrical.
Unlike other posters here, I wouldn't try looking for transceivers with biasing (failsafe) resistors integrated. The nodes should have a high Z when listening, the failsafe (and termination!) should be a function of the bus, rather than an individual transceiver. To achieve that the A/B inputs are always "within the ballpark" at each individual node, you should use a reference ground - with a 100 Ohms resistor at each node as some would say, or attached straight. If the local ground wobble is too much, use isolation. Biasing at each node doesn't get you anywhere. Unless your reference grounds are isolated (floating), any biasing resistors are just too weak to overcome hard earth loops. And, if the signal pair shielding is individual and tight, i.e. the transmission line is more like a twinax, then the shielding is an appropriate reference ground! as the shield is effectively a third conductor in the RF energy transmission sense. Any conductor that you ground at one end only, becomes an antenna at its own wavelength.
I've tried AC termination before (RC) with coax lines (for IRIG). You should take a look with a scope, what the actual result is - at the terminator, and at any transceiver nodes halfway down the line. Try experimenting with too much and too little capacity.
Your general formulas for capacitor choice seem correct, you're reasoning in the right direction. And I do feel that at least RC (AC-focused) termination is appropriate even at lines that are "too short and too slow", as the UART's can have several sampling points within a single bit length, or if there's just a single sampling point, you cannot be sure exactly where it is...
That said, my general feeling is: you should not care about DC load all that much. The transmitters (transceiver IC's and their power supplies) are principally designed to handle 60 Ohms DC at their output, 24x7. And, straight DC termination at both ends of the transmission line are your best bet.
If your TX/RX pattern is full duplex and such that the transmitter is always on, your concern may have some credit - if OTOH the communication pattern is "sparse", i.e. the transceivers spend most of their time in high Z, it doesn't make much sense to be obsessed with DC load.
And, in a transmission line, the transmitter should be impedance-matched too! In misc RF systems, this is normally done by series termination at the transmitter. Not sure exactly about RS485 (FET's switching hard to the power rails), especially if your transmitter is always on - maybe check with a 'scope, with and without termination "at the transmitter end" (if your "always on master" really is at one TML end) but as I already said, don't be overly concerned about load presented by the second terminator. As a homework, I should probably take a scope and watch a 485 transmitter at one end of the line switching from active state into high Z :-)
BTW, you have linked to some USB/485 dongle (your master node) but that's a complete circuit in an opaque plastic box, we do not know the details of its inside wiring. I would bet that inside it, you'll find an SN75176 or some more modern work-alike. And, it likely will be reverting to high Z if the FIFO and "transmitter holding register" ever get empty.
===EDIT===
For a perfect RF TML impedance match at the transmitter, the TX chip would need to switch the power rails to the TML through a local resistance of 60 Ohms differential, or in the real world 30 ohms effective in series with each pin (A/B). This also makes sense as a short circuit protection (current limit). Looking into the SN75176 datasheet I can see no explicit series termination, neither in series with the line outputs, nor with individual totem switches - but I do recall that the signal amplitude does decrease somewhat, as you attach the first and the second terminator. The datasheet does mention a current limit of 60 mA during TX at the A/B terminals - again considering the internal schematic, this would have to be some inherent non-destructive limit of the totem switches (or maybe they are actually current sources). Note that any activity going on in the chip's output totems is bounded by the 0/+5V power rails. A full 5V into 120 Ohms would mean 83 mA. At 60 mA, the diff output amplitude on a properly terminated line will be 60 Ohms * 60 mA = 3.6 V. I.e. in that scenario, the effective differential impedance of the chip is 23 Ohms (1.4V left to +5V, /60mA).
frr
  • 2,573
  • "how did you arrive at that asymmetrical setup?" - to attempt to match the voltage levels I saw from the master device, which were also asymmetric. – Reinderien Feb 12 '18 at 18:56
  • "If your TX/RX pattern is full duplex" - it isn't; it's half-duplex at all times – Reinderien Feb 12 '18 at 18:58
  • Asymmetric waveforms? That's curious. I recommend that you do not care about some slight asymmetry. Seen that before too. Transceivers from different vendors apparently can be "tilted" a few per cent in this or that direction. And, if your local reference ground is derived from some mains return, the ground "wobble" can appear on a 'scope reading as the two nodes having their outputs "DC shifted" against each other (or rather, "riding a sinewave" :-) There's no point in "shorting" pin A or B to the ref.GND by a resistance too small. – frr Feb 12 '18 at 20:22
    The asymmetry was not slight, it was significant. The master was putting out marks and spaces both above ground, marks slightly above ground and spaces somewhere halfway to 5V (can't remember the exact values) – Reinderien Feb 12 '18 at 20:26
  • If the transmitted waveform from a transceiver chip is heavily impaired, inspect your dongle's transceiver chip. I've seen (and read reports of) transceiver chips being broken in some name-brand USB/485 dongles, ex works. Forged/fake chips, apparently. After replacement of the 8legged transceiver, all was fine. This kind of problem tends to fully blossom with a 120-Ohm terminator attached (or two). If you have an oscilloscope, consider yourself lucky. Many 485 practitioners do not have one. – frr Feb 12 '18 at 20:28
    Just to make sure: the transceivers are powered by +5V vs. local GND (which also serves as a good reference ground). And, the output of the transceivers, each pin of A/B, moves between +5V and GND. I.e., the two outputs are always above the local GND when transmitting. They can only move under GND sometimes, if you're receiving another node's transmission and the ref.gnd potentials are different between the two nodes = the transmitting far node's GND is lower at the moment than your local GND at the node where you're watching. – frr Feb 12 '18 at 20:33
    I have some oscillograms of healthy transceivers (and various types of bus termination) on my web page referred above. If you have some oscillograms of what you consider flawed output, maybe post them here :-) – frr Feb 12 '18 at 20:44
I think you have over complicated things. Why not to use a terminator resistor 120 ohm on both ends, it is simple and most reliable.
As you said you don't have stubs, the entire transmission line is daisy chained, the cable has the specified characteristics impedance, then the best is to use 120 ohm resistor at both ends.
The smart thing when using PC is to have an isolated type RS485 transceiver and having those pullup/pulldown enabled. Not all devices like the pull-ups. Some of them work expect A pulled high an B pulled low, and some A pulled low and B pulled high. Check this.
EDIT: My recommendation. Don not use the shield as 3rd conductor. The shield has to be connected to earth at each node, but only one end. Overall, each part of the shield is connected at erath only in one point. No direct connection from master to end node over shield exists.
Marko Buršič
  • 23,562
  • Bidirectional parallel termination is indeed simple, but not reliable if it doesn't work at all. As I said, if I use simple parallel termination, the line is far from being fail-safe, and spurious start bits are always seen. The DC load on the driver is too high, and the app note warns about this. – Reinderien Aug 01 '17 at 12:43
    The pullup/pulldown are fixed and cannot be enabled or disabled. They haven't been the issue; in fact, they're too weak to provide failsafe operation in the presence of 120 ohm termination, which is why I had to add my own power termination network, and why I now want to pursue AC termination. – Reinderien Aug 01 '17 at 12:46
    In my career I have installed dozens of RS485, Profibus, CAN networks. 80m long transmission line is simple, but you have to have the right hardware (I was always in industrial range app). Many times there are the issues with bad transceiver hardware, incorrect shield connection, etc...Can you report any measurements to find the real problem? – Marko Buršič Aug 01 '17 at 13:48
  • @Reinderien Can you link the hardware: both master and slave? – Marko Buršič Aug 01 '17 at 13:50
  • Sure - the slave was already linked. I've added a link to the master. – Reinderien Aug 01 '17 at 13:57
  • @Reinderien The transceiver chip itself is not an adequate information about slave. The schematics around the transceive would help. Also a simple schematics of the wiring, how did you connect the entire network. – Marko Buršič Aug 01 '17 at 14:05
    The schematic has been added. I already know "the real problem", shown in my description above; I'm curious as to alternatives from the application note. Thank you. – Reinderien Aug 01 '17 at 17:37
  • @Reinderien Do the slaves have galvanically isolated transceiver section? – Marko Buršič Aug 01 '17 at 17:52
    Nope. What you see is what's there. Whereas I think an isolation stage could be highly beneficial, and something I'll read about separately, that wouldn't be answering my questions about AC termination. – Reinderien Aug 01 '17 at 18:04
  • I greatly appreciate your recommendation, but it does not answer my questions. – Reinderien Aug 01 '17 at 18:11
  • @Reinderien In such case it will be difficult. I had bad experience with non-isolated RS485. They are mostly used as point to point, not multi-drop. Some industrial manuals also state that clearly. – Marko Buršič Aug 01 '17 at 18:12
What you want to do is find the minimum hysteresis value for a differential signal and conduct enough current through the line termination resistance for at least twice the minimum Vrh (Receiver Hysteresis voltage) voltage on as many loads as you are going to have. The load resistance is another data sheet value and the 120 line impedance resistor is added in parallel to that.
For the MAX485, for instance, Vrh (Receiver Hysteresis) is 70mV and Rrl (Receiver Load Resistance) is 12K. With just 2 of these, the load at each end with dual 120 Ohm termination resistors is 59 Ohms. With 140mV and 59 Ohms, we need 2.37mA of current. That means VDC minus Vrh*2 divided by our calculated load current giving us 2.050K. Dividing by 2 and our ideal failsafe resistances are 1K. You only need one of these at the terminating resistor locations. The values you would use elsewhere would need only 12.5uA (12K Rrl) so would be dual 180K resistors.
Your best bet under 115K and either simplex or full duplex is single ended termination as a transmit only chip output doesn't need termination. Half duplex is where terminating both ends helps.
Joseph Perkins
  • 174
