I am trying to install MIcroPython Firmware on my ESP8266-12E chip. I am using esptool.py to flash the firmware. I have successfully uploaded the firmware esp8266-20170612-v1.9.1.bin followed by a flash_erase. I have used following commands to flash the chip.
$ sudo esptool.py --port /dev/ttyUSB0 erase_flash
  esptool.py v2.0.1
  Connecting........_
  Detecting chip type... ESP8266
  Chip is ESP8266
  Uploading stub...
  Running stub...
  Stub running...
  Erasing flash (this may take a while)...
  Chip erase completed successfully in 13.0s
  Hard resetting...
$ sudo esptool.py --port /dev/ttyUSB0 write_flash --flash_mode qio --flash_size detect 0x0 esp8266-20170612-v1.9.1.bin --verify
  esptool.py v2.0.1
  Connecting....
  Chip is ESP8266
  Uploading stub...
  Running stub...
  Stub running...
  Configuring flash size...
  Auto-detected Flash size: 4MB
  Flash params set to 0x0040
  Compressed 598432 bytes to 390604...
  Wrote 598432 bytes (390604 compressed) at 0x00000000 in 34.5 seconds (effective 138.8 kbit/s)...
  Hash of data verified.
  Leaving...
  Verifying just-written flash...
  (This option is deprecated, flash contents are now always read back after flashing.)
  Verifying 0x921a0 (598432) bytes @ 0x00000000 in flash against esp8266-20170612-v1.9.1.bin...
  -- verify OK (digest matched)
  Hard resetting...
As you can see verification of flash process is OK. And I can see a new wifi ssid on my wifi list.
Now when I am trying to access REPL via picocom it is hanging on following:
picocom v1.7
port is        : /dev/ttyUSB0
flowcontrol    : none
baudrate is    : 115200
parity is      : none
databits are   : 8
escape is      : C-a
local echo is  : no
noinit is      : no
noreset is     : no
nolock is      : no
send_cmd is    : sz -vv
receive_cmd is : rz -vv
imap is        :
omap is        :
emap is        : crcrlf,delbs,
Terminal ready
I also tried screen, putty and minicom same behaviour on them as well. Also encountered a strange behaviour that it is working perfectly via ESPlorer.
Is there anything that I am missing? Or any suggestion to hunt this situation?
Thanks
  • I would try different baud rate - i would check 74880bps "boot log" baud rate or other that might be set by micropython (you would need to dig through micro python docs) – mazurnification Jul 31 '17 at 08:27
  • Did you try to press ctrl-D on picocom? Just to do a microcontroler reset. – danihp Aug 25 '17 at 20:13
  • This worked for me as well. This solution is also documented on the MicroPython getting started guide for ESP8266 at https://docs.micropython.org/en/latest/esp8266/esp8266/tutorial/intro.html. – JTW Oct 14 '17 at 23:34
I was having a similar problem with a Wemos D1 mini board. Erasing and Flashing the firmware worked. However I was getting no REPL prompt, resetting was giving me garbage. I solved it by adding "-fm dio" when writing flash.
esptool.py --port /dev/ttyUSB0 --baud 460800 write_flash -fm dio --flash_size=detect 0 esp8266-20170823-v1.9.2.bin
I had the same problem, checked my setup (bare ESP8266 module) 100+ times and it definitely was correct. I could flash the ESP, but could not connect afterwards. Problem had something to do with my breadboard/wiring; bad junctions (maybe because of dirt/glue). Did the exact same wiring on another board with cleaned resistors, now it works.
I had the same problem with ESP8266 ESP-12E, but -fm dio did not help. Surprisingly, flashing in another mode, dout (Dual Output) helped:
esptool.py --port COM11 --baud 460800 write_flash -e --flash_size=detect -fm dout 0 esp8266-20190529-v1.11.bin
Greenonline
  • 2,064
  • 38
