I have a VCSEL packaged in a TO-46 can (image here / datasheet with package dimensions). I need to remove the glass top – with or without the silver-coloured cylinder – without damaging the laser diode itself or any electrical contacts within the package. What would be the best method to achieve this?
Asked
Active
Viewed 208 times
1Most likely magic. Do you have many to experiment? – PlasmaHH Jul 25 '17 at 13:15
If you mean equipment, I have most standard lab tools and a microscope available. If you mean magic, I'm afraid I do not. – hryghr Jul 25 '17 at 13:26
I meant many of those diodes. I personally would try chopping up the can with a mill or so. But only if I see a reason to do so, which here I do not ;) – PlasmaHH Jul 25 '17 at 13:29
I only have one piece to experiment on, I'd rather not touch the other. The reason is that I want to minimize any kind of optical feedback into the active region and chopping it up is arguably a little extreme of a measure. – hryghr Jul 25 '17 at 13:35
I've taken the top off broken ones. I think I used a Dremel tool with the thin grinding wheel. I took it off near where the silver can meets the gold colored base. – George Herold Jul 25 '17 at 13:59
Hi op, I smell a bit of an [XY problem cooking up](http://xyproblem.info). Can you explain *why* you want to do this? – Marcus Müller Jul 25 '17 at 14:11
So you want to minimize the crosstalk, to improve the contrast? – analogsystemsrf Jul 25 '17 at 14:56
Basically I want to see whether the so called polarization switching occurs if I minimize the optical feedback into the VCSEL. The slightest feedback can change the polarization dynamics drastically, according to several papers I have read. – hryghr Jul 25 '17 at 21:53
Polarization switching (and other kinds of mode hops) is highly feedback-dependent...but the glass lid is probably AR coated and/or angled to minimize the feedback it produces (assuming the device is meant to be used in applications where hops would be a problem). The optics you use to couple the laser output to a fiber or detector are equally or more likely to be causing a problem. – The Photon Jul 25 '17 at 21:57
As far as I know, the VCSEL has no "internal" polarization stabilizing mechanism, therefore I doubt they put in any more effort to avoid switching. Of course my hopes that switching would occur by increasing the current (after the disassembly) are not too high, but I want to give it a go. I do not couple the output to fiber as of now, the light directly reaches a PBS cube (I know I should collimate it first), then lensed photodiodes detect it in both directions. – hryghr Jul 25 '17 at 22:03
I have not used it, but Thor Labs sells a tool for exactly this purpose.
It supposedly works for cans with diameters between 2 and 24 mm.
Note that for a VCSEL there is no "rear facet", so the feedback to the monitor photodiode may depend on a reflection off the can's window. If you remove the can, it may no longer possible to use the photodiode to maintain constant power operation.
The Photon
- 126,425
- 3
- 159
- 304
I must have missed this one, since I frequently browse their site. The photodiode is not of much interest as for now, but thank you for pointing it out. – hryghr Jul 25 '17 at 21:52
