I am working on a project that requires measuring absorbance of a solution.
The circuit consist of an emitter led, a photodiode attached to an opamp with \$10^7\$ gain (TIA). The solution absorbs light from the led and causes different voltages corresponding to different concentrations. This works well for large concentration solution.
For example the voltage obtained with solution of:
- 0 mol/l (no solute) is 9.95V
- 100 micromol/l is 8.92V
But for concentrations <=5 micromol/l the voltage is also 9.95V, which indicates that the change in voltage is so small that I cannot measure it.
How can I improve sensitivity? I considered increasing the gain, but it can lead to a maximum of 100V detected. An opamp's saturation is around +/-15V.
