-2
What is the difference between an open loop amplifier and a voltage follower (unity gain buffer)?
user1083734
  • 365
    stevenvh's answer to [your previous question](http://electronics.stackexchange.com/questions/31943/why-is-feedback-resistor-required-in-op-amp-circuits) answer this well. – MikeJ-UK May 15 '12 at 13:31
    Did you try to research about it? – clabacchio May 15 '12 at 16:02
  • @clabacchio nope, why research when you can ask people questions cheaply and have the answer with no effort, right? Isn't it logical, I think it is the correct thing to do... – abdullah kahraman May 15 '12 at 16:03
  • I posted this after recieving a reply on a previous question: http://electronics.stackexchange.com/questions/31888/basic-frequency-control-circuit. I did google both amplifiers but wanted a direct comparison, which I could not find. stevenvh had not answered any of my questions at the time of this question's posting. Please do not assume I am trying to cheat answers out of fellow users. I am new to electronics.stackexchange.com and am a novice at all things electronic. I apologise for the way my question appears to lack consideration. I would delete this question if it was not already answered – user1083734 May 15 '12 at 16:30
I just posted this as an answer to another question, but I can reuse it here :-) (without the part about the non-inverting amplifier).
edit
Oops, I hadn't noticed the question is from the same person as the other one.
Let's look at the most simple feedback situation:
The opamp will amplify the difference between \$V_+\$ and \$V_-\$:
\$ V_{OUT} = 100 000 \times (V_+ - V_-) \$
Now \$V_+ = V_{IN}\$ and \$V_- = V_{OUT}\$, then
\$ V_{OUT} = 100 000 \times (V_{IN} - V_{OUT}) \$
or, rearranging:
\$ V_{OUT} = \dfrac{100 000}{100 000 + 1} \times V_{IN}\$
That's as good as
\$ V_{OUT} = V_{IN}\$
This is a voltage follower, a \$\times\$1 amplifier, which is mostly used to get a high input impedance and a low output impedance.
The feedback reduces the very high amplification to \$\times\$1. Note that the high amplification is needed to get \$ V_{OUT}\$ as close as possible to \$V_{IN}\$.
The open loop amplifier will have the high amplification you can see in the transfer function
stevenvh
  • 145,145
  • 455
  • 667
