Why don't you use the CMSIS library? There is a specific function for that.
Moreover, This is the Code taken from CMSIS Library for System Software Reset:
* @file: core_cm3.h
* @purpose: CMSIS Cortex-M3 Core Peripheral Access Layer Header File
* @version: V1.20
* @date: 22. May 2009
* Copyright (C) 2009 ARM Limited. All rights reserved.
* ARM Limited (ARM) is supplying this software for use with Cortex-Mx
* processor based microcontrollers. This file can be freely distributed
* within development tools that are supporting such ARM based processors.
* THIS SOFTWARE IS PROVIDED "AS IS". NO WARRANTIES, WHETHER EXPRESS, IMPLIED
* OR STATUTORY, INCLUDING, BUT NOT LIMITED TO, IMPLIED WARRANTIES OF
* MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE APPLY TO THIS SOFTWARE.
* ARM SHALL NOT, IN ANY CIRCUMSTANCES, BE LIABLE FOR SPECIAL, INCIDENTAL, OR
* CONSEQUENTIAL DAMAGES, FOR ANY REASON WHATSOEVER.
/* memory mapping struct for System Control Block */
typedef struct
__I uint32_t CPUID; /*!< CPU ID Base Register */
__IO uint32_t ICSR; /*!< Interrupt Control State Register */
__IO uint32_t VTOR; /*!< Vector Table Offset Register */
__IO uint32_t AIRCR; /*!< Application Interrupt / Reset Control Register */
__IO uint32_t SCR; /*!< System Control Register */
__IO uint32_t CCR; /*!< Configuration Control Register */
__IO uint8_t SHP[12]; /*!< System Handlers Priority Registers (4-7, 8-11, 12-15) */
__IO uint32_t SHCSR; /*!< System Handler Control and State Register */
__IO uint32_t CFSR; /*!< Configurable Fault Status Register */
__IO uint32_t HFSR; /*!< Hard Fault Status Register */
__IO uint32_t DFSR; /*!< Debug Fault Status Register */
__IO uint32_t MMFAR; /*!< Mem Manage Address Register */
__IO uint32_t BFAR; /*!< Bus Fault Address Register */
__IO uint32_t AFSR; /*!< Auxiliary Fault Status Register */
__I uint32_t PFR[2]; /*!< Processor Feature Register */
__I uint32_t DFR; /*!< Debug Feature Register */
__I uint32_t ADR; /*!< Auxiliary Feature Register */
__I uint32_t MMFR[4]; /*!< Memory Model Feature Register */
__I uint32_t ISAR[5]; /*!< ISA Feature Register */
} SCB_Type;
#define SCS_BASE (0xE000E000) /*!< System Control Space Base Address */
#define SCB_BASE (SCS_BASE + 0x0D00) /*!< System Control Block Base Address */
#define SCB ((SCB_Type *) SCB_BASE) /*!< SCB configuration struct */
#define NVIC_AIRCR_VECTKEY (0x5FA << 16) /*!< AIRCR Key for write access */
#define NVIC_SYSRESETREQ 2 /*!< System Reset Request */
/* ################################## Reset function ############################################ */
* @brief Initiate a system reset request.
* @param none
* @return none
* Initialize a system reset request to reset the MCU
static __INLINE void NVIC_SystemReset(void)
SCB->AIRCR = (NVIC_AIRCR_VECTKEY | (SCB->AIRCR & (0x700)) | (1<<NVIC_SYSRESETREQ)); /* Keep priority group unchanged */
__DSB(); /* Ensure completion of memory access */
while(1); /* wait until reset */
