I'm trying to export images of a board i made for testing purposes in order to use them for laser-cutting. I am using Eagle to create the board layout and export the images, but no matter what I do the images include areas outside the board. I am exporting the images using the command "EXPORT IMAGE image.bmp MONOCHROME 2048;". If, for example, I had a potentiometer in my board that had its shaft outside the board area, the output image would include that and therefore be much bigger than the board. I want the image output to be constrained to the board. Is there any way I can do that?
Thank you,
Riccardo
