I am trying to use the CAN controller in Kinetis E06 (FRDM-KE06Z). I have based my code on "FRDM-KEXX Driver Library Package". For a start I try to send (and later receive) a frame in loopback mode.
This is my initialization code (obd_can_init is called just once at startup, FreeRTOS has nothing to do with it as only one task is running):
#include "obd_can.h"
#include <FreeRTOS/include/FreeRTOS.h>
#include <FreeRTOS/include/task.h>
#include <MKE06Z4.h>
#include <string.h>
#if DEFAULT_BUS_CLOCK == 20000000
//Values were calculated using the spreadsheet in dev_documentation directory
#define CANBTR0_500KBAUD 0xC3
#define CANBTR1_500KBAUD 0x34
#define CANBTR0_250KBAUD 0xC7
#define CANBTR1_250KBAUD 0x34
#else
#error "CAN baud registers not defined for this bus clock!"
#endif
#define DEBUG_TERMINAL 0
#include <debug.h>
static void obd_can_transmit(uint32_t identifier, const uint8_t *payload, uint8_t payload_length);
void obd_can_init(void){
    portENTER_CRITICAL();
    SIM->SCGC |= SIM_SCGC_MSCAN_MASK;
#ifndef BOARD_EVK //EVK uses CAN_TX PTC7 and CAN_RX PTC6, which is the default setting
    SIM->PINSEL1 |= SIM_PINSEL1_MSCANPS_MASK; //CAN_TX PTE7, CAN_RX PTH2
#endif
    portEXIT_CRITICAL();
    MSCAN->CANCTL1 = MSCAN_CANCTL1_CANE_MASK /*enable CAN module*/
            | MSCAN_CANCTL1_CLKSRC_MASK /*use bus clock*/;
    MSCAN->CANCTL0 |= MSCAN_CANCTL0_INITRQ_MASK; //enter controller initialization mode
    while (!(MSCAN->CANCTL1 & MSCAN_CANCTL1_INITAK_MASK)){
        //wait for the controller to enter initialization mode
        vTaskDelay(2);
    //set baud
    MSCAN->CANBTR0 = CANBTR0_500KBAUD;
    MSCAN->CANBTR1 = CANBTR1_500KBAUD;
    MSCAN->CANCTL1 |= MSCAN_CANCTL1_LOOPB_MASK; //enable loopback for testing
    MSCAN->CANRIER = MSCAN_CANRIER_RXFIE_MASK; //enable RX interrupt
    //RX filter
    MSCAN->CANIDAR_BANK_1[0] = 0;
    MSCAN->CANIDAR_BANK_1[1] = 0;
    MSCAN->CANIDAR_BANK_1[2] = 0;
    MSCAN->CANIDAR_BANK_1[3] = 0;
    //RX filter mask - accept all identifiers
    MSCAN->CANIDMR_BANK_1[0] = 0xFF;
    MSCAN->CANIDMR_BANK_1[1] = 0xFF;
    MSCAN->CANIDMR_BANK_1[2] = 0xFF;
    MSCAN->CANIDMR_BANK_1[3] = 0xFF;
    MSCAN->CANIDAC = MSCAN_CANIDAC_IDAM(0); //use two 32-bit acceptance filters
    MSCAN->CANTIER = MSCAN_CANTIER_TXEIE_MASK; //enable TX interrupt
    NVIC_SetPriority(MSCAN_RX_IRQn, 5);
    NVIC_EnableIRQ(MSCAN_RX_IRQn);
    NVIC_SetPriority(MSCAN_TX_IRQn, 5);
    NVIC_EnableIRQ(MSCAN_TX_IRQn);
    MSCAN->CANCTL0 &= ~MSCAN_CANCTL0_INITRQ_MASK; //exit initialization mode
    while (MSCAN->CANCTL1 & MSCAN_CANCTL1_INITAK_MASK){
        //wait for the controller to exit initialization mode
        vTaskDelay(2);
    debugf("OBD CAN initialized");
    uint8_t data[] = {1,2,3,4};
    obd_can_transmit(10, data, sizeof(data));
This is my transmission code:
static void obd_can_transmit(uint32_t identifier, const uint8_t *payload, uint8_t payload_length){
    uint8_t empty_buffer_index = MSCAN->CANTFLG & MSCAN_CANTFLG_TXE_MASK;
    if (!(empty_buffer_index)){
        debugf("TX busy, dropping frame");
        return;
    debugf("Using buffer %d", empty_buffer_index);
    //select transmit buffer
    MSCAN->CANTBSEL = MSCAN_CANTBSEL_TX(empty_buffer_index);
    uint32_t* identifier_ptr = (uint32_t*)&MSCAN->TEIDR0; //assumes little endianness
    *identifier_ptr = identifier;
    memcpy((uint8_t*)&MSCAN->TEIDR0, payload, payload_length); //copy payload
    MSCAN->TDLR = payload_length;
    MSCAN->TBPR = 0; //priority of this buffer
    //enable transmission of this buffer
    MSCAN->CANTFLG = MSCAN->CANTBSEL & MSCAN_CANTBSEL_TX_MASK;
My terminal shows:
9:obd_init: OBD initialization
74:obd_can_init: OBD CAN initialized
88:obd_can_transmit: Using buffer 7
88:obd_can_transmit: Using buffer 6
88:obd_can_transmit: Using buffer 4
So it looks like the transmission is never started and send calls just put data into subsequent buffers. What am I doing wrong that does not trigger transmission?
filo
  • 8,801
The problem was that some of MSCAN registers can be written only in initialization mode, some only OUT of initialization mode and some in both modes.
TX & RX interrupt enable registers (CANTIER, CANRIER) had to be written after exiting initialization mode and everything worked fine afterwards.
filo
  • 8,801
