I've got a simulation that simply takes an address as an input and 64 clock cycles later it simply outputs it on another port. For some reason, when I register the output data, it is not delayed by a clock cycle (see waveform). Is this some crazy part of the standard or did I find a bug in the delta step of my simulator?
Testbench:
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity bug_report_tb is
end bug_report_tb;
architecture TB of bug_report_tb is
-- MIG UI signal declarations
signal app_addr : std_logic_vector(29 downto 0);
signal app_en : std_logic;
signal app_rdy : std_logic;
signal app_rd_data : std_logic_vector(29 downto 0);
signal app_rd_data_r : std_logic_vector(app_rd_data'RANGE);
signal ui_rst : std_logic;
signal ui_clk : std_logic;
begin
process(ui_rst,ui_clk)
begin
if ui_rst = '1' then
app_en <= '0';
app_addr <= (others => '0');
elsif rising_edge(ui_clk) then
app_en <= '0';
if app_rdy = '1' then
app_en <= '1';
if app_en = '1' then
app_addr <= std_logic_vector(unsigned(app_addr)+1);
end if;
end if;
end if;
end process;
process(ui_clk)
begin
app_rd_data_r <= app_rd_data;
end if;
end process;
module : entity work.bug_report_mod
port map
ui_clk => ui_clk,
ui_rst => ui_rst,
app_rd_data => app_rd_data,
app_rdy => app_rdy,
app_en => app_en,
app_addr => app_addr
end TB;
Module:
library ieee;
entity bug_report_mod is
port
ui_clk : out std_logic;
ui_rst : out std_logic;
app_rd_data : out std_logic_vector(29 downto 0);
app_rdy : out std_logic;
app_en : in std_logic;
app_addr : in std_logic_vector(29 downto 0)
end bug_report_mod;
architecture behavioral of bug_report_mod is
signal clk : std_logic;
signal reset : std_logic := '1';
signal app_en_sr : std_logic_vector(63 downto 0) := (others => '0');
signal dly_counter : unsigned(6 downto 0);
signal rdy_counter : unsigned(6 downto 0);
signal app_rdy_int : std_logic;
type int_array is array(natural range <>) of integer;
signal addr_array : int_array(63 downto 0);
begin
process
begin
clk <= '1'; wait for 2.5 ns;
clk <= '0'; wait for 2.5 ns;
end process;
ui_clk <= clk;
ui_rst <= reset;
app_rdy <= app_rdy_int;
process
begin
wait for 50 ns;
wait until clk'event and clk = '1';
reset <= '0';
wait for 2 ms;
end process;
process(clk)
begin
if rising_edge(clk) then
if app_en_sr(63) = '1' then
app_rd_data <= std_logic_vector(to_unsigned(addr_array(63),app_rd_data'LENGTH));
end if;
end if;
end process;
process(clk,reset)
begin
if reset = '1' then
app_rdy_int <= '0';
rdy_counter <= (others => '0');
dly_counter <= (others => '0');
elsif rising_edge(clk) then
app_en_sr <= app_en_sr(62 downto 0) & (app_en and app_rdy_int);
addr_array <= addr_array(62 downto 0) & (to_integer(unsigned(app_addr))*4);
rdy_counter <= ('0' & rdy_counter(5 downto 0)) + 1;
app_rdy_int <= not rdy_counter(6) and dly_counter(3);
if dly_counter(3) = '0' then
dly_counter <= dly_counter + 1;
end if;
end if;
end process;
end behavioral;
