I'm trying to use TFT display with ILI9341 8080 16 bit interface with STM32F407 via FSMC. I'm using HAL. To explain a bit more, for ILI9341 command registers only lower 8 bits of the bus are used, full 16 bit bus width is only used for transfer of image data (in RGB 565 format). I tested the program before with identical display configured with 8080 8 bit interface and it worked flawlessly.
I have image data in MCU memory in uint16_t format and use
HAL_SRAM_Write_16b
for transfer of image data and
HAL_SRAM_Write_8b
for transfer of commands and command parameters.
Now, when I select
hsram1.Init.MemoryDataWidth = FSMC_NORSRAM_MEM_BUS_WIDTH_8;
everything works fine, only image data (colours and resolution) are wrong of course, because ILI9341 has only lower 8 bits of data (blue and half of the green bits) and upper 8 bits are zero. As soon, as I select
hsram1.Init.MemoryDataWidth = FSMC_NORSRAM_MEM_BUS_WIDTH_16;
display shows black and grey stripes for a second and then just goes white – error state.
I use A16 for command / data selection, therefore address of command memory is 0x60000000 and data memory 0x60010000, hopefully same for 8 bit and 16 bit bus width?
Question: Can anybody explain to me, how data transfer in FSMC_NORSRAM_MEM_BUS_WIDTH_16 mode works, more precisely when I use HAL_SRAM_Write_16b (or HAL_SRAM_Write_8b) in this mode, if the data are sent one 16 bit (or 8 bit aligned to lsb) word per time frame, or if the MCU somehow distorts / combines them.
wildfireheart
  • 245
    How are the IM pins (to select the interface mode) configured on your display? There are 8 different parallel bus options between 8/9/16/18-bits and either mode I or mode II for all of them. – brhans Jun 28 '17 at 11:16
  • @brhans I'm using ER-TFTM024-3 display on pre-made PCB from buydisplay.com on which IM pins should be already connected. According to [datasheet](http://www.buydisplay.com/download/manual/ER-TFTM024-3_Datasheet.pdf) it should be 8080 16-bit mode I. – wildfireheart Jun 28 '17 at 11:50
Turns out that address bits differ between 8-bit and 16-bit addressing mode. In 8-bit addressing it's mapped to bits [0-23] and in 16-bit to [1-24], so if you want to use A16 pin as CMD / DATA selection, the address of DATA transfer is 0x60010000 in 8-bit mode and 0x60020000 in 16-bit.
Source: STM32F4 Reference Manual: 36.4.1 NOR/PSRAM address mapping
wildfireheart
  • 245
