I'll start by saying I'm a bit new to electronics. I found a wall to usb charger at a surplus store. It is rated to put out 5.0V and 0.7A. I'm using it right now to power something else which is working fine but I wanted to learn more about how this supply works.
Here are some pictures of it. I already removed the usb connector to use for another project.
http://i.imgur.com/QIfQO.jpg
I think its a flyback converter? I can see that it first goes through a full wave rectifier and then into some unidentified chip. I assume the chip does the pwm because it goes right into the transformer. Am I way off? Is there anything else I'm missing that I should read up on?
Brian Carlton
  • 13,252
  • 43
  • 64
JDD
  • 445
    possible duplicate of [How do the tiny AC->USB power supplies work?](http://electronics.stackexchange.com/questions/31018/how-do-the-tiny-ac-usb-power-supplies-work) – Olin Lathrop May 04 '12 at 23:28
    You should do the grunt work of reverse engineering the PCB and making a diagram. This is hard to do from a photograph and tedious to do for someone else's benefit. Full wave rectifier into chip could just point to simple voltage regulation. – Kaz May 05 '12 at 00:35
Those are much nicer and clearer pictures than people usually provide ! :-).
You could work out the circuit by tracing out the design from the PCB.
It will be something like a "TOPSWITCH" which is one brand of highly integrated switching controllers allowing mains to low voltage conversion with minimal components- as you can see. Your description is probably essentially correct - rectified mains feeds a flyback converter which comnnects via an isolation transformer to low voltage output. It looks nicely done compared to some such.
TOPSWITCH product page here.
Example application note and troubleshooting guide
Example of minimum parts count converter. Real world solutions end up with more parts than this - and end up looking like eg
More and more and more
Note that this is only one brand - there are similar IC's from a range of manufacturers - Asian sourced parts may be devices not normally sold in the West.
Russell McMahon
  • 147,325
  • 210
  • 386
It is a switching power supply. The transistor (probably in the control IC) turns on, pulling current through the primary. As I understand it, this stores energy in the transformer (don't ask me how!) and when the current stops flowing through the primary, it appears on the secondary multiplied by a ratio determined by the number of turns on each side. This current is stored in the capacitors on the output, and you get a DC output.
It's this energy storage and release that makes the design so simple and you find flybacks in almost any modern low power electronics designed to plug into mains power. You don't tend to find them in higher power applications because beyond around 40W they are inefficient compared to other designs, but they are very good for <=40W and used almost exclusively.
It's like a normal mains transformer, but to keep the size and cost down, it's much, much smaller, and operating at a much higher frequency.
However, it isn't a stunning example of SMPS wall warts to be honest:
It appears this PSU has no feedback loop as it doesn't have an optocoupler for a control signal. It could be using the Vcc rail to regulate, but that is rare...
In a discontinuous flyback (which this almost certainly is) the capacitors take almost all the ripple current. Those caps are far, far, far too small to handle a ripple current of 700mA. Maybe 50mA each on a good day.
Especially notice the tiny primary capacitors, which look like 4.7µF or so each; this may just about be enough for a supply with a feedback loop, but is completely insufficient if there is no feedback loop (there will be considerable 100/120Hz hum on the output.)
Also notice the lack of essentially any line filter, meaning any claim to CE/FCC/etc compliance (required to sell in most countries) is probably forged.
They cheap ones are often unsafe too, but you can't tell until you dissect the transformer. Some really cheap ones are too good to be true.
Thomas O
  • 31,546
  • 57
  • Thanks for the info! I was trying to figure out if it had an optocoupler. I'm glad you pointed out that there isn't one. That video was great. I bet this one is the same case. A thin piece of tape between me and the mains. I kind of want to rip it apart to find out. – JDD May 05 '12 at 01:56
