I'm trying to implement a jump to the STM32F091 USART1 bootloader from my application.
I'm using the following function(based on https://community.st.com/thread/40238-stm32l476rg-jump-to-bootloader-from-software):
void SB_SystemBootloaderJump()
typedef void (*pFunction)(void);
pFunction JumpToApplication;
HAL_RCC_DeInit();
SysTick->CTRL = 0;
SysTick->LOAD = 0;
SysTick->VAL = 0;
* Step: Disable all interrupts
__disable_irq();
/* ARM Cortex-M Programming Guide to Memory Barrier Instructions.*/
__DSB();
// __HAL_SYSCFG_REMAPMEMORY_SYSTEMFLASH()
// /* Remap is bot visible at once. Execute some unrelated command! */
// __DSB();
// __ISB();
JumpToApplication = (void (*)(void)) (*((uint32_t *) ((0x1FFFD800 + 4))));
/* Initialize user application's Stack Pointer */
__set_MSP(*(__IO uint32_t*) 0x1FFFD800);
JumpToApplication();
From APP Note AN2606: System Memory address as in picture: https://i.stack.imgur.com/VdcZY.png
From SWD Utility, memory contents at System Memory: https://i.stack.imgur.com/wGkfH.png
From Debugger, SP and Reset handler as picture: https://i.stack.imgur.com/Qb08r.png
Program execution up to breakpoint at Bootloader address : https://i.stack.imgur.com/bFfRM.png
Considering: A - Using a jumper to VCC on BOOT0 pin, I can successfully access the system bootloader via STM32 Flash Loader Demo. The same is not true if I jump to the bootloader from my app. B - I'm using a FTDI FT230x USBxSerial Bridge.
Questions:
1 - Since I'm using the absolute system memory address, there is no need to use __HAL_SYSCFG_REMAPMEMORY_SYSTEMFLASH()
. Correct?
2 - Am I missing something on this function?
3 - Is there a timeout between the bootloader starting and receiving the "0x7F" byte on USART1?
4 - Will opening/closing the serial port affect the bootloader? Do I have to reset the MCU if I close the serial port and open it again?
