I'm building my own hobbyist microprocessor-controlled reflow oven. I'm using (mechanical) relays to turn the heaters (i.e. quartz tubes) on or off. I've noticed heating lags a couple of seconds before the temperature starts to rise.
For now I'm managing the temperature profile manually with the assistance of an Arduino, which just turns the heaters off when the set temperature is reached. For instance when I set the temperature to, say 120° Celsius and the heaters stop, the temperature still climbs 10-20 degrees so there is quite a bit of overshoot then some ringing, which decreases slowly.
I've read and watched many examples that make use of a PID for a better temperature control. Without that I would just stop the heaters, like 10-20 degrees below the set value and turn them on/off in short periods afterwards until the temperature stabilizes around the set value. I just know the delta varies with the temperature so it might not be as straightforward — I know about the exponential nature of temperature rise with a fixed set value.
So can anybody explain in layman's terms how a PID accounts for the inertia, e.g. what role the integral part and what the derivative part play in simple terms, as well as how/if I can figure out rather intuitively an estimation of the derivative and integral quantities without resorting to complex calculations.
TonyM
  • 21,742
  • 39
  • 62
  • The challenge is the delays, as you've seen. Thus the key to control is in examining the slewrates and derivative of slewrates – analogsystemsrf Jun 17 '17 at 14:45
  • @analogsystemsrf I think I've got it actually. As you can read I just have some difficulty trying to make the link between *this* (theory) and *that* (practice). In short: *what is the part that compensates for the delay and how*? –  Jun 17 '17 at 14:56
    Delays are horrible to deal with. Perhaps caused by a sensor too far from the heater. Or a heater too large, with too much thermal mass. PID scaling factors can change greatly when the physical arrangement is changed. Decreasing delays helps achieve PID control factors yielding smaller errors. – glen_geek Jun 17 '17 at 14:57
  • You cannot really implement a PID if the only control you have is turning the heater on and off with a relay. – user57037 Jun 17 '17 at 16:00
  • @mkeith: Sure you can! As long as the switching period is short relative to the response of the load it's fine and a 3 to 20 s cycle time wouldn't be unusual on industrial systems. For reliability, of course, an SSR beats a relay but PID *is* possible with the relay control. The PID output is used to adjust the duty cycle. – Transistor Jun 17 '17 at 16:21
  • @Transistor, interesting. I honestly didn't know you could cycle relays that fast over an extended period. So it is just PWM control with a PWM period of several seconds or more? And maybe some duty cycle restrictions also? – user57037 Jun 17 '17 at 16:37
    I use industrial temperature controllers for work. The ones with relay output generally limit the cycle time to 5 s minimum. The ones with a solid-state DC output to drive an SSR don't have this restriction. If you think about an application with a long time-constant - a glass furnace or one tonne of chocolate, for example - you could imagine that a 30s duty cycle might be adequate to control it well. – Transistor Jun 17 '17 at 16:58
I had to + Glen's comment. He consistently has his brain in the right place, IMHO. There is nothing harder to deal with in a PID than a \$\Delta t\$ delay. I've been dealing with lamp-heated temperature controls for IC wafer FABs, in some fashion or another, for years. Let me start with an overview of PID and talk a little about where it is NOT going to be as useful as in other cases. I'll also suggest one of many other domains of control methods you could also explore, but with a priority of steps you should first take before going elsewhere.
The canonical expression for PID control is:
$$u_t=K\cdot\left[e_t+\frac{1}{T_i}\int_0^t e_\tau\:\textrm{d}\tau+T_d\frac{\textrm{d}\:e_t}{\textrm{d}\:t}\right]$$
With the controller parameters being the proportional gain \$K\$, integral time \$T_i\$, and derivative time \$T_d\$.
  1. Proportional control: The control action here is simply proportinal to the control error. (The above equation reduces to \$u_t=K\cdot e_t+u_b\$, where \$u_b\$ is a controller bias or reset.) An analysis of a static process model shows that the resulting process has a residual offset or controller bias at steady-state (though a system can be adjusted manually to that the there may be a control error of zero at one and only one setpoint value by a proper choice of the controller bias.) Increasing the gain also provides gain to the measurement noise (bad), so the loop gain should not be too high and there is no "best" loop gain as it depends upon the objectives.
  2. Proportional + Integral control: The main function of integral action is to make sure that the process output agrees with the setpoint in steady state. With integral action, a small positive error will always result in an increasing control signal and a small negative error will always result in a decreasing control signal. This is true no matter how small the error is.
  3. PID control: Adding derivative control improves the closed-loop stability. (It will take some time before a change in the control is noticed in the process output. So the control system will be late, correcting for that error. The upshot of the derivative term is that it is a kind of prediction made by extrapolating the error using a tangent to the error curve, used to anticipate the delayed results.
The above description, added to your own description of your problem of a delay, would suggest that a derivative term would help you. But as usual, nothing is necessarily so simple.
Proportional-integral control is sufficient when the process dynamics are of a 1st order. It's easy to find this out by measuring the step-response. (If the Nyquist curve lies in the 1st and 4th quadrants only.) It can also apply in cases where the process doesn't require tight control, even if it isn't of 1st order.
PID control is sufficient for processes where the dominant dynamics are of 2nd order. Temperature control is often the case here. So, once again, this perhaps argues for adding derivative control in your situation.
However. All the above should only be considered after you've done everything else possible to improve a few things:
  • Use the fastest responding temperature sensor you can reasonably apply (small mass, pyrometry, etc) and apply it in a situation with the least possible response delay to the process you want to control (close, not far.)
  • Reduce the delay variation in taking measurements and enacting process control.
I want to elaborate a little on this last point. Imagine process control as kind of like you standing somewhere, trying to poke a thin, very flexible and wobbly bamboo pole into a distant bird-house hole that is sitting in a tree above and away from you. If you are close and the bamboo pole is short, it's easy. You can do it every time quickly and easily. But if the bamboo pole is long and the bird-house far away from you, it's very, very hard to do. The pole keeps wandering around and it makes your prediction and control very difficult.
(If it's not already clear, the length of the bamboo pole is like the loop delay time.)
So delay is probably the WORST NIGHTMARE of control systems. More delay is very bad. So it is very important that you do everything in your power to reduce this delay. But there's one more important point.
Now imagine the same situation. But now the bamboo pole keeps changing in length, too. Sometimes it is shorter, sometimes longer, and it varies continually without prediction on your part. You now have to keep changing your stance and you never know when the delay will change. This is the situation that exists if your SOFTWARE doesn't control very carefully and with an iron-fist, the time delay in processing your ADC value and generating a DAC control output.
So, while delay is bad enough to a PID control system. Variable delay is even worse. So you need to pay strict attention to your software design -- very strict attention -- so that you don't have IF statements and conditional calculation code, or sloppy use of timers, etc., all of which can cause significant variations in the delay between sample and control output.
You need to get the above into management before THEN worrying about whether or not you need derivative control. First things first. Clean up your act. Then examine the system to determine what remains to do (using PI vs PID, for example.)
I was working on PID control systems using an extremely accurate pyrometer system (also very expensive to customers.) I received a call from a Canadian researcher working with our pyrometer, but using a separate PID controller from a very large commercial company (the biggest in the world doing these things.) The researcher was struggling with ripples down the side of a boule of gallium arsenide he was pulling from a melt. And wanted my help in figuring out the right PID control variables. (In boule-pulling, you want very uniform diameters.)
The controller he was using was quite good by any standard measure. But it added delays --- and those delays varied too, as the software inside it didn't rigorously control the delay it introduced to the overall control loop.
So the first thing I told him was that I'd add PID control to the software in our pyrometer and that he should simply PULL the external controller from the system he was using. I added that software in less than a week and shipped him the modified pyro system. I didn't do anything fancy with the PID software. However, I kept my variability in ADC to DAC to less than a couple of microseconds and tightened up the overall delay as well to about 100 microseconds. I shipped that to him.
I received a call Monday the next week. The boules were pulling out almost perfectly, with no ripple at all.
It was as simple as just cutting down the delays and also cutting down the variability in those delays. Nothing special about the PID control, at all. It was a plain vanilla implementation that anyone would produce first time learning about one.
This illustrates the importance of squeezing out delay and delay variability. Sure, derivative control can provide some kind of "secant/tangent" idea of prediction. But nothing replaces getting the delays down and keeping the variability to an absolute minimum, as well.
Just keep thinking about the bamboo pole and the bird-house hole problem.
Conclusion?
Control of systems with a dominant time delay are notoriously difficult. I've suggested some reasons you might believe that a derivative term will help with time delays. But there is general agreement that derivative action does not help much for processes that have dominant time delays. This is why I'd immediately suggested helping that researcher by eliminating all the delays I could easily remove (like an external PID box, for example.) I didn't imagine that my implementation was better than the commercial product. I knew my implementation wouldn't be nearly as well-vetted, in fact. Cripes, I had to write it from scratch, test it and install it, and ship out a unit with newly added software it never had before in it, and do all that in a week's time. But I also knew that the delay was KILLING all the chances that this researcher had in getting the results he wanted. So I immediately knew that the best approach was to squeeze out the delays and not to invent some "brilliantly" implemented magic PID code that only a genius could follow. It's all about the delays and how those delays vary, first and foremost. The rest is all a much lower priority.
There are some things called "dead time compensators." But in the final analysis, you need to do everything you can to pull out delays and pull out variability in those delays. And then, after you've done all you can there, if there is still a problem it is likely you need more sophisticated controls than a PID allows. Here, I'd reach for fourier transforms (and using an inverse transform to analyze the step-responses and develop a description of the system responses), perhaps. You can do a lot with these that cannot be touched with PID. Almost miraculous results, in fact, if you can model the response function well enough.
But in your case I'd focus on squeezing out delays and their variability. I think you should, if possible, consider avoiding the use of simplistic on/off lamp control, too. It would be nice if you can control the lamp intensity. But I don't know if you can consider that.
jonk
  • 77,059
  • 73
  • 185
    Thanks a lot, jonk, that was quite an in-depth (to me) explanation. The delay I talked about well, I'm afraid I cannot reduce it as I believe it's inherently how the oven is made — I modded a general purpose oven into a reflow oven as is commonly found on the internet. However despite using quartz tubes, temperature rise is half the required rate (not more than 1°C per second instead of 2-3). As for the sensor I'm using a pair of K thermocouple and I checked it has little to no inertia. The one thing I've noticed though is the temperature lag decreases if I pre-heat the oven, i.e. around 50°C. –  Jun 17 '17 at 17:54
  • Have you tried the Smith Predictor Controller to mitigate the delay? – Chu Jun 17 '17 at 18:16
  • @Chu Not yet, I only learnt about it here :-D. Moreover my oven is partly disassembled presently and I don't have my hands on it. –  Jun 17 '17 at 20:58
  • I've accepted your answer first for how elaborate and detailed it is. Also because I was open to using whatever fits, even if it implied not a PID. Your answer and Transistor's gave me enough hints on what to do next. There can be only one [accepted answer] though. *Thanks a lot to everybody anyway*. –  Jun 18 '17 at 09:55
This doesn't directly answer your question but gives you some tools to play with to improve your understanding.
There's a simple Excel simulator over at Engineers-Excel which you may find helpful.
Figure 1. PID simulator model.
The tricky part is modelling your process - the oven - to establish K - process gain, Ts - the response time constant and Ls - the response lag. I suggest:
  • Switch your oven on at, say 40% power (\$P_1\$)and see what temperature it stablises at. Repeat at, say, 70% power (\$P_2\$) and record the temperature. The process gain is given (for this range of settings) as $$ K = \frac {T_2 - T_1}{P_2 - P_1} $$ and the answer will have the rather odd units of degrees/%.
  • Plot the temperature response over time as you switch between \$P_1\$ and \$P_2\$. \$ L_S \$, the lag time, is the time between switching and when the temperature begins to rise.
  • \$ T_S \$ is the time (from start of response) until the temperature reaches 63% (one time constant) of the way from the \$ T_1 \$ to \$ T_2 \$.
After that you can play with the PID parameters to see if you can get the response you desire.
Taking some wild guesses:
  • \$P_1 = 40 \%\$ and \$T_1 = 92°C\$.
  • \$P_1 = 70 \%\$ and \$T_2 = 176°C\$.
  • \$ K = \frac {176 - 92}{70 - 40} = 2.8 °C/\% \$.
  • \$Ls = 3 \; s\$.
  • It takes 50 s to get 63% of the way from 92°C to 176°C so \$ T_S = 50 \; s\$.
Figure 2. Excel PID simulator output.
You generally get away with a zero D term if your process is not likely to get disturbances such as sudden change in setpoint or sudden change in thermal load. That simplifies things down to a PI control setup.
For heating you can get proportional power by switching the power fully on and off sufficiently fast relative to the thermal response time.enter image description here
Figure 3. Variable duty cycle for AC control of a heater.
Transistor
  • 168,990
  • 186
  • 385
  • Thanks for the understandable technical information. Just a side note: since I use relays, which I found out are cheaper than SSRs (source: Digi-Key), I can only turn the heaters either fully on or off, there's no possible adjusting between 0% and 100%. Also I cannot use zero-crossing to switch the heaters off but I guess that's of least importance. Anyways thanks a lot for your insights. –  Jun 17 '17 at 17:31
    My Figure 3 shows on-off control and it's what you will be doing and it's fine. You will be *averaging* anywhere you wish between 0 and 100%. Effectively it's a slow pulse-width modulation (PWM) with AC. You will trade off keeping the cycle time reasonably short with relay life. Zero-crossing is nice in that it reduces electrical noise. If it's not a problem then it's not a problem! – Transistor Jun 17 '17 at 17:35
In PID there are 3 parts: Proportional, Integral and Derivative.
Proportional is the most simple controller. It amplifies the error between desired and actual signal. E.g. if desired temperature is 100C, actual is 80C, then output = 20 * Kp. How much output is given is tuned by Kp.
If you tune Kp too low, there is not enough heating, and it may never reach the desired temperature.
If you tune Kp too high it may ramp up too fast. Inertia may lead to overshoot and ringing. That is because there is a delay between giving a certain output power and measuring it's effect.
The integral part is necessary if you want low static offsets. Note that for a P controller to give an output, it must have an error present to generate any output value. If you want error to be very close to zero, you need the I-part to take over from P. This may take some time however.
The derivative part is probably most interesting for your inertia problem. The derivative looks at the rate of change of the error. If there is a large rate of change in the error, it means there is a high inertia. Using a tuned factor Kd you can make sure that the output will throttle back in time. This is so that the inertia slows down before it reaches the final output value.
This allows you to use a high(er) P factor for adequately aggressive response, while using D to prevent overshoot. The I part is used to make static error will eventually settle to 0.
Hans
  • 7,238
  • Actually, in the long term it is the P term which drops to zero, since the I term integrates to exactly the set point, leaving the output difference at zero, and P times zero is zero. – WhatRoughBeast Jun 17 '17 at 15:20
