Can anyone explain to me if there is the Early effect in MOS transistor then the Early effect affects the expression for VOV which is \$VOV=\sqrt{\frac{2ID}{kn'(W/L)}}\$?
Asked
Active
Viewed 1,461 times
1This is mentioned in **any** decent book about MOS transistors but anyway: The Early effect or **Base-width modulation** only happens in Bipolar transistors. In MOS transistors there is a similar effect (which I would never call Early effect) called **Channel length modulation**. It basically lowers the output impedance when the transistor is used as a current source. – Bimpelrekkie Jun 06 '17 at 14:43
1Yes, its the \$( 1 + \lambda V_{DS} )\$ you see in the equation for drain current in saturation. – sstobbe Jun 06 '17 at 14:49
1https://electronics.stackexchange.com/questions/298829/common-drain-jfet-output-resistance-problem/299030#299030 – G36 Jun 06 '17 at 14:56
