High quality laser diodes often require temperature controllers plus a "TE" (thermoelectric unit) that cool the diode and maintain it at a particular temperature using a Peltier cooler.
Why not just cool the diode without a controller? Is there some problem with the diode being too cold?
Tyler Durden
  • 2,186
  • 49
It depends.
Some lasers will indeed get less efficient if they're too cold.
In some systems, you may want to keep the laser at a fixed operating wavelength, and this requires operating the laser at a fixed temperature.
Cooling the laser below 0 C could cause ice to form on the laser (if it's not in a hermetic package), impacting performance and reliability.
If none of those apply, excessive cooling will simply consume power unnecessarily, increasing the power consumption and the demand on the cooling system for the whole system or plant.
A TEC controller can be as simple as a 6-pin microcontroller, so it doesn't add much cost to the system, after you've already budgeted for the TEC module itself and the components to drive it efficiently, so even if the benefits are small it might still make sense to add the controller.
The controllers I am talking about are ones like the Newport 325 which can cost as much as $1,200 new.
The $1200 mostly pays for the display and user interface and a remote control interface (GPIB, USB, or ethernet), as well as the amortized cost of R&D to develop the design and its software, NRTL listing, etc.
You'd buy one of these instead of building your own if you're only building a small number of systems (maybe only one). $1200 is less than the cost of designing, building, testing, and debugging a new controller design, even if the cost of materials for the new design approaches $0.
Many laser users (say, biology researchers, or even electrical engineering researchers in other specialty areas) may not even be skilled in PCB design, control systems, embedded programming, mechanical engineering, and other skills needed to develop a controller on their own.
The Photon
  • 126,425
  • 159
  • 304
  • The controllers I am talking about are ones like the Newport 325 which can cost as much as $1,200 new. – Tyler Durden May 22 '17 at 00:34
  • What system **requires** that kind of controller? – The Photon May 22 '17 at 00:35
  • I don't know. You tell me. That's why I am asking the question. – Tyler Durden May 22 '17 at 00:36
  • You asserted "high quality lasers often require...". Give some concrete examples if you want a more specific answer. – The Photon May 22 '17 at 00:37
  • I wrote that on the basis that Newport and Thor Labs both sell fancy temperature controllers and obviously they would not do that unless there was some need. – Tyler Durden May 22 '17 at 00:42
    On top of what's in my answer, there's of course also the "nobody ever got fired for ordering IBM" effect. In the case of benchtop TEC controllers, ILX (now a division of Newport) is the IBM of the industry. – The Photon May 22 '17 at 01:06
  • The short version of this is: if you need a laser diode to operate at constant wavelength and power, you need a temperature controller. If you want a packaged instrument with display, power supply, and remote IO, you want it to support many different temperature sensors, and you don't want to build it yourself, it is going to cost a few hundred dollars minimum. ILX is on the expensive end, but there aren't comparable devices at 1/10 the price. Its about the features and flexibility, not the accuracy of temperature control. – Evan May 22 '17 at 04:22
  • @Evan, out of curiousity, do you know any reputable vendor at 50% or even 75% of ILX's prices? – The Photon May 22 '17 at 04:28
  • It has been a while since I looked, but I remember thorlabs having some slightly cheaper stuff, but not by half for comparable specs. I have used their T-Cube controller, which is $750, but only suitable for low power lasers. – Evan May 22 '17 at 04:57
The temperature controller is not only for "cooling" the laser diode to get higher efficiency, but it is also used to set the laser diode (actually the NTC near the laser chip) at a constant temperature. The main purpose is to get a constant power and wavelength output. For example, the commercial DFB laser diodes have a typical wavelength to temperature coefficient of ~ 0.1nm/degree, for some applications that are wavelength sensitive (DWDM, coherent applications using narrow linewidth lasers), the temperature must be held constant with very low noise (<1e-3 Kelvin). For these applications, an ultra-low noise current driver is also needed (CW most of the cases).
evildemonic
  • 8,698
  • 44
for CW solid state lasers the reason is to maintain a constant current flow in a device that is not linear in current draw
biggie
