I've designed a circuit but realized now - when the 200+ boards finally arrived - that I've made a mistake.
Long story short: I made the prototype on a breadboard, using OPA2132 (because that's what I had at home) coupled as a comparator (fixed ref at in-, signal at in+). The breadboard version somehow worked like a charm, but when sitting on the PCB the output is never brought down to GND when in- (6.5V) > in+ (1.8V). Instead, the output is around 1V, and that screws everything up.
Being a hobbyist, I cannot afford to buy new boards, so the only solution here is to find pin-compatible comparator (SO8) that does not cost a fortune, that I can replace. OPA2132 is not open-collector. Vcc for my circuit will never be over 13V, and it's single fed (no negative voltages).
How can I find a replacement IC without browsing through zillions of datasheets?
OPA2132 datasheet: http://www.ti.com/lit/pdf/SBOS054
