I'm developing a small robot using the STM32L152C Discovery board. I'm currently trying to configure the board using the STM32CubeMX. I've never worked at this very-low level (my experience is much more about algorithms), therefore I started doing simple things, like sending few characters to the UART port. The board doesn't have an external oscillator. Therefore I'm using the internal RC oscillator.
After doing this I wrote a very easy software that sends continuously a character to the UART port:
void SystemClock_Config(void);
static void MX_GPIO_Init(void);
static void MX_USART2_UART_Init(void);
int main(void)
HAL_Init();
SystemClock_Config();
MX_GPIO_Init();
MX_USART2_UART_Init();
unsigned char msg = '@';
while (1)
HAL_UART_Transmit(&huart2,&msg,1,1);
Using a 100 MHz oscilloscope this is what I get out of the pin:
The character that I'm sending is clearly visible, but it seems that the output is something like unstable. I've pressed the AUTO button on the scope many times, but nothing changes.
I thought that maybe it could be a problem with the RC oscillator. After setting the clock frequency to 4.194 MHz (the maximum) with the STM32 configurator, I've measured the clock but the output is not what I would expect.
This is what I get:
First I've noticed that the wave is not so "squared", and also the frequency is slightly different: 4.202 MHz instead of 4.194 MHz.
I would like to understand better why I get this output.
Concerning the shape, since the oscilloscope is 100 MHz and the clock has a frequency of ~4 MHz, I guess that the measuring tool is not the issue. Concerning the frequency, I would say that the problem is in the accuracy of the RC oscillator itself. Can these be the cause of the problem I'm getting on the UART?
