I have some motors to be used in copters, can anyone tell me:
a) if they are BLDC
b) how could I find what current they would draw and their power ratings?
c) what ESC should I use for it
a) if they are BLDC
If they only have two leads, they are not BLDC, probably just brushed DC motors.
BLDC motors generally have 3 leads for the windings. Sometimes there are even more leads for Hall effect posistion sensors.
They are N60 size brushed motors, probably with weak Ferrite magnets and metal brushes. As such they are not likely to be suitable for high power/weight applications.
Brushed motors wear out with use. Even high quality coreless motors only last a few hours when used in model helicopters. Second-hand motors recovered from old equipment already have some wear so they will last even less time.
You should look for motors which are specifically designed for helicopters of the size you want to power. Quadcopters need matched motors with identical characteristics except two are timed for clockwise rotation and the other two anticlockwise. These are often sold as a set of 4.
